20 Most Recent Viper (VGC421) Remote Control Questions & Answers
0answers
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
12/4/2008 3:37:11 AM • Viper (VGC421)... • Answered on Dec 04, 2008
2answers
Why cant I use the viper 7857V with the 7701 system? Or how would I do it
Check the difference in the remote codes.
1/18/2022 8:54:10 PM • Viper Televison... • Answered on Jan 18, 2022
4answers
7941v display dark
Would like to know this as well. Having the same issue
5/8/2019 2:02:00 AM • Viper Televison... • Answered on May 08, 2019
How can I fix my viper remote ASAP? it's acting crazy
Please provide more information in regards to your problem.
3/5/2019 12:40:38 AM • Viper Televison... • Answered on Mar 05, 2019
I have a Viper RPN
Refer that question to the manufacturer of the device.
9/8/2017 8:08:42 PM • Viper Televison... • Answered on Sep 08, 2017
2answers
I bought a used dodge pickup equiped with a viper
On many of the Viper models, the symptom you are describing is because the remote battery is low. The remote can't be too far from the vehicle. If it is, the system see it as you forgot about the vehicle being remote started, and shuts it back down. A weak battery creates a weak signal and makes the unit 'think' you are far away. The Viper website has instructions on how to disable the whole system, there are many different versions, so find the box and get the model number from it, you will need that to get any further.
6/2/2017 5:48:25 PM • Viper Televison... • Answered on Jun 02, 2017
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote. 1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .Remote should be program
8/18/2016 5:23:21 PM • Viper Televison... • Answered on Aug 18, 2016
I have a viper 714v2 remote, how do i program this to my vehicle
vehicle make, model, year?
10/9/2015 9:27:02 PM • Viper Televison... • Answered on Oct 09, 2015
My remote for my viper car starter is beeping constantly all of a sudden non stop going through all 4 lights one at a time and now the Aux light is flashing and beeping. How do I stop this?
It has been damaged. Buy an other one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
7/30/2015 12:20:43 PM • Viper Televison... • Answered on Jul 30, 2015
Viper car alarm lock and unlock works fine but will not let key turn
spray oil into lock
12/12/2014 1:17:09 PM • Viper Televison... • Answered on Dec 12, 2014
I have a viper 479v , i don't know what i did , but now don't make a sound when i lock and unlock and start the car, what i do for get the sound
I assume you are talking about the sound the body computer generates, I would suggest taking it to the dealer to get it re-programed if that is the problem.
11/25/2014 5:02:34 PM • Viper Televison... • Answered on Nov 25, 2014
How to replace the battery for 7211v
hellllllllo........go to goggle enter model number the video will appear battery # CR-2016...........tkx.......g.scott
10/12/2014 1:41:08 AM • Viper Televison... • Answered on Oct 12, 2014
Car cranks, no spark to plugs. 1982 Buick skyhawk. How do I trobleshoot
if no spark then you need to check the coil pack it sounds like it may be the problem..
6/5/2014 6:11:17 AM • Viper Televison... • Answered on Jun 05, 2014
tip
Viper remote not charging or no display
This is for the two way pager style remotes. If the remote no longer charges or it does not display anything then it could use a new rechargeable battery. This is usually the case for 9 out of 10 problems. This battery is much like the one in your cell phone and has a chargeable life. Over time and charging it gets weaker. Also if you leave the remote uncharged for a very long time there is a good chance the battery will not recharge. If you need to go on vacation for a very long time, charge the remote and then disconnect the battery from the remote. It takes about one minute after you reconnect the battery too the remote for it to start back up. This does nothing to the pairing of the remote or system, the remote saves all of that info in it and does not require battery power to keep it saved. Here is a website to purchase new batteries viperremotebattery.com and a youtube video how to change it. http://www.youtube.com/watch?v=GGnG5iCX09A Thanks, Hopefully I can help someone in need because these remotes are very expensive.
Viper (VGC421) Remote Control Logo
6 questions posted
Top Viper Televison & Video Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Viper Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Viper Televison & Video
Most Popular Question
viper remote starter sets off alarm
  • Televison & Video
