20 Most Recent Universal Remote Control MX-500 LCD Remote Control Questions & Answers
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
Universal Remote... | Answered on Jun 26, 2014
Blu-Ray players can't be synchronized with any other remote controls, except its original one. Don't waste time and damage the player's firmware by experiments.
Universal Remote... | Answered on Nov 27, 2012
2. Auto Scan With Three-Digit Number
You can also program your remote control by sending out a
series of Power Off commands for different brands stored
in the library by using the following steps. This is similar
to the first method, except it is easier to move through all
of the device codes for your device and make note of each
one that turns your device OFF.
1. Manually turn on the device you plan to operate.
2. Go to the SETUP mode by pressing both the MAIN and
ENT buttons simultaneously for three seconds.
3. Press the P-PRO button next to the LCD screen.
16
17
4. Programming the MX-500TMto Control Your Components
4. The remote will be flashing "SELECT BUTTON".
Press the device you wish to program. (For example, to
program TV, press the TV button.)
5. The remote will be flashing "FROM TABLE". Select the
device from which the scanned code will be selected.
(Important: If you have already relabeled your device
keys, your LCD screen will not look like the illustration
above. Select the appropriate LCD button for the "FROM
TABLE" using the labels as shown in the illustration on
page 11 of this manual. For example, if you have relabeled
AUX as LIGHTS, you would still push the bottom-left
button to access the AUX Code Table.
6. Point the remote control toward the component and
alternately press the UP (or DOWN ) button on the LCD
and the Power button. If the right code number is sent, the
component will turn off right after the code number is
transmitted.
(Please press the UP (or DOWN ) button within 20 seconds
of beginning programming, otherwise the remote will
revert to the SETUP menu, and then after a period of time,
it will go back to the MAIN device page.)
18
7. Confirm that it is the right code by pressing the Power
button. After you have confirmed that the right code is
entered, save the code by pressing the SAVE button on the
LCD.
8. Confirm that you entered the right code number that
matches your component by pressing other functional
buttons. If any of the buttons do not operate, as they
should, please repeat from Step 1.
9. Continue to program other components by repeating
from step 1 above.
10. You can press EXIT at any time if you do not wish to
proceed.
11. Exit from Preprogrammed mode by pressing the MAIN
button and then exit from the SETUP mode by pressing the
MAIN button once again.
Universal Remote... | Answered on Sep 14, 2011
Hello
Pre programmed codes with MX-500 to JVC are
240 163 191 114 266 279 291
OK
Universal Remote... | Answered on Mar 19, 2011
Battery is low or almost empty, change with the new one. And make sure there are nothing block TV receiver and remote control, plastic or paper or something else.
Universal Remote... | Answered on Feb 11, 2011
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
Universal Remote... | Answered on Dec 24, 2010
These are the codes for toshiba Television
007, 015, 030, 040, 062, 101, 138
Thanx
Universal Remote... | Answered on Jul 22, 2010
There is no "bulb" in the unit. The MX-500 provides power to an electroluminiscent strip that runs from the top to the bottom of the remote. When power is applied, the whole strip glows inside.
Sounds like your light switch is going bad. Not sure what the life of the EL panel is but the part number is A015-J1
Universal Remote... | Answered on Apr 07, 2010
when you buy a remote they give you some instructins and a list whit codes, follow these instructions or try on this site to ask ather instruction: https://www.2instructions.com/search.php?cmarque=PX-RC1&modele=PX-RC1
Universal Remote... | Answered on Feb 14, 2010
If you have a MX-500 use your origional remote to teach the MX-500 the codes.
Universal Remote... | Answered on Sep 21, 2009
This remote may have a screw under the label on the rear if not it is a 'snap together' type which usually can be prised open using a very thin screwdriver but be careful you dont slip and injure yourself.
HOW CAN I GET THE CODES FOR MY SANYO T.V TO WORK CAUSE I CANT SEEM TO GET IT WORKING WITH MY PX-RC1 ROMOTE IF ANY ONE KNOW WHO TO HELP ME CAN YOU PLZ TELL ME HOW ITS DONE THANKS
Universal Remote... | Answered on Aug 02, 2009
The MX-500 has a learning mode that you can use. Press MAIN and ENT together for 3 seconds, then press the P-PRO button. Select the device then button you wish to program on your remote and then with both remotes facing each other (IR ports must be able to communicate) press the button on your other remote.
You can also download a copy of the book here...
http://www.universalremote.com/resources/pdfs/MX500manual.pdf
Universal Remote... | Answered on May 28, 2009
If you have a learning universal remote, such as the MX-500, just put the remote in learning mode, press the button on the universal remote you want to program then press the appropriate button on the other remote. Otherwise, we'll need to know also what remote control you have. They are not all alike.
I would suggest you use the learning mode and teach your remote from the remote that came with the Sony
Universal Remote... | Answered on May 03, 2009
Universal Remote Control MX-500 LCD Remote Control Logo
36 questions posted
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Remote Control Televison & Video
Most Popular Question
vizio model xvt3d554sv tv uses
  • Televison & Video
