20 Most Recent Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Questions & Answers
Thank you for your response. After I posted ? a button was discovered. Problem solved! I did add this to my ? box yesterday.
Universal Remote... | Answered on Mar 02, 2019
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls.
Universal Remote... | Answered on Nov 07, 2018
My remote model #is ur8050T AND i NEED THE CODES.
Universal Remote... | Answered on Apr 30, 2018
Hampton Bay is a Home Depot brand name. Most (not all) have a lifetime warranty. I think that if you take it to the nearest HOME DEPOT store, WITH the receipt they will help you by fixing or replacing the remote.
We have our home completely covered by HAMPTON BAY fans and one went out after several years and they replaced it no charge for another fan.
We have had great success with HOME DEPOT products and shop there often. Our preferred store is the one in Mesquite, TX on I635 East.
Universal Remote... | Answered on Feb 05, 2018
"universal" doesn't mean universal among different brands in the fan world.
Universal Remote... | Answered on Apr 30, 2017
If there is a set-up code to Toshiba TV to this Sony remote; you can set it up. In most cases, there won't be a code with Sony remote with Toshiba. Anyway, if you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Universal Remote... | Answered on Aug 19, 2016
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Universal Remote... | Answered on Sep 03, 2015
I need to replace my hampton bay remote control part #G9P2BTAUC7052T for my ceiling fan and light.Where do I get one
Universal Remote... | Answered on Feb 15, 2015
1. try ebay
2. stores sell universal remotes that can work most ceiling fans.
You should be able to get a universal remote for a ceiling fan at home depot or lowes. Be aware they only sell then WITH the remote and the receiver unit as a package. Be aware, you'll need to check the 4 "dip pin" positions on the receiver unit on the fan itself to program the new remote. Yes, you'll have a spare receiver left in the package unless you choose to install the new one. You may have to remove the fan to do this, as they're usually found in the canopy (where the fan hangs from the box in the ceiling.) Often, the dip switches are just left all "up," however, they could easily have been changed. Some fans are programmable now, and you can test the code without having to check the receiver in the fan (similar to an older TV remote.) If you're using this for a TV, Satellite dish, etc, you'll need to find a compatible one online (not necessarily that model, it's "UNIVERSAL" and follow the instructions that come with it. TV and Ceiling fan remotes operate totally differntly, so if you have a remote that does both tasks, it's fairly new technology, and you'll have to follow instructions for the one you purchase.
Universal Remote... | Answered on Feb 13, 2015
Universal Remote... | Answered on Jan 04, 2015
Please, I need new one control thank you
Universal Remote... | Answered on Oct 26, 2014
Try this link for the ceiling fan remote it should be remote style M. I want a spare so I found this web page (page down)http://www.eceilingfans.com/ceiling_fan_remote_controls.html
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
360 questions posted
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Remote Control Televison & Video
Most Popular Question
hampton bay
  • Televison & Video
