20 Most Recent Rancilio Rocky Espresso Coffee Grinder - Doser Questions & Answers
tip
Rancilio Rocky w/ doser: clean sweep of coffee grounds
The Rancilio Rocky coffee grinder is a superb, highly recommended machine, but its doser is pretty useless in the home. First reason: you want to grind coffee instants before you brew or pull your espresso shot; otherwise, the grinds just lose aromatics and flavor. The doser only works for multiple doses, so you're better off just grinding the amount you need each time. If you're buying a Rocky, get the doserless model.
If you have the doser model, like I do, you also find that the vanes which sweep the coffee into your portafilter or cone leave a layer of grounds on the doser floor. If not cleaned out, they turn rancid. There are coffee web sites with fairly complicated instructions on how to modify the vanes to do a clean sweep. Here's the simple way:
Flip up the doser cover, and spin the vanes while pressing your finger lightly on the outer top edge of one vane. The vanes have enough play so the pressure brings one into light contact with the doser floor, sweeping 99% of the grounds into your waiting portafilter.
I have a Rocky Grinder. The spring that pulls the
no, dont worry. Just return the lever by hand. Replace the spring and it will break again. It is a hassle to replace and not having it will not affect the function
9/20/2009 8:22:35 AM • Rancilio Rocky... • Answered on Sep 20, 2009
Not fine enough for espresso
solved please donate on my paypal account [email protected] to get the answer
7/10/2009 9:39:19 AM • Rancilio Rocky... • Answered on Jul 10, 2009
2answers
Rancilio grinder does not grind fine enough for espresso
After taking the top burr off several times and rescrewing it, I finally was able to exert enough force to get it to turn a couple of extra turns. Evidently there was some oil or coffee gunk (although I could see none) that snagged the bur. Now it appears to work as before.
This is a great, service by the way. Even the process of thinking through the problem so I could post it helped me solve it.
7/9/2009 6:58:13 PM • Rancilio Rocky... • Answered on Jul 09, 2009
I just got a used Rocky grinder. It works great but I read about
the grinding itself makes noise. if you have noise in empty spinning than you should consider changing bearings( 2 of them) in the motor.
during opening grinder pay attention to lower holder of burr which spins together with axis, try to be gentle with that part.
4/4/2009 7:48:39 AM • Rancilio Rocky... • Answered on Apr 04, 2009
Adjusting grind on Rancilio Rocky
  1. because it didn't work a wilde the upper burr holder could be jammed, carefully take id off, clean it good and then put it back until you touch lower burr with the upper.
  2. to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean grinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
3/30/2009 4:27:41 PM • Rancilio Rocky... • Answered on Mar 30, 2009
Rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
3/30/2009 1:16:04 PM • Rancilio Rocky... • Answered on Mar 30, 2009
Replacement portafilter holding fork
i will give you one web adress, i hope it is near you.
http://imp.mallcom.gr/coffee/coffee-rancilio.pdf
www.nuovaricambi.it
3/30/2009 8:17:47 AM • Rancilio Rocky... • Answered on Mar 30, 2009
Rancilio Class 10 Espresso Machine. It is not reaching the right pressure, the water comes hot but there is not enough pressure for preparing an espresso. What could be the failure, the pump?
Question edited for clarity. Service manual in the link. Test water temperature and pump pressure. These machines need servicing every 6 to 12 months depending on use. https://www.google.com/search?q=rancilio+class+10+espresso+machine+service+manual ..
4/14/2024 6:04:30 PM • Rancilio Coffee... • Answered on Apr 14, 2024
I need more temperature from my espresso machine
Often these temperature differences are solved by descaling. Do never use vinegar. One can buy citric acid crystals or powder (not the same as lemon juice) and dissolve that chemical in water. I buy it in the Chinese Mall. Do not make a too strong acid. Shops sell maintenance powder which is the same but that is quite expensive. Let the acidic water go in and through the coffee maker until it looks clear. Next rinse with water for quite a number of runs. You may see how strong the citric acid that you make is by descaling something else and wait for about an hour. Another acid to be used in coffee makers is lactic acid. Lactic acid is bought as a cleaning agent. Also very strong and to be diluted with water.
12/10/2023 12:15:56 PM • Rancilio Coffee... • Answered on Dec 10, 2023
Rancilio Two-Group Automatic Classe 10 Espresso Machine. No software error message?
Question edited for a lot more clarity. Did you try a Power Reset so that the internal software operating system reloads? Pull the mains plug. Wait 10 minutes. Press and hold the Power button for 2 minutes to dissipate main board power. Plug back in and turn on. If that doesn't work, phone them up. https://www.google.com/search?q=rancilio+classe+10+no+software https://www.manuals.ca/rancilio/classe-10-sde/manual?p=128 ..
8/17/2023 4:34:45 PM • Rancilio Coffee... • Answered on Aug 17, 2023
Why is the hot water tap pouring out black water
Tis Iron sediment keep running water thru it it'll clear up. If there's any way to run some vinagar thru it that would help greatly.
1/20/2023 10:30:27 PM • Rancilio Coffee... • Answered on Jan 20, 2023
My Rancilio S24's hot water valve suddenly started leaking. How do I repair?
From your description and info replace valve.
5/11/2022 7:42:22 PM • Rancilio Coffee... • Answered on May 11, 2022
2answers
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken. Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally. This might be a good opportunity to give the grinder a thorough cleaning. Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :) If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels. Good luck, Villi 25504831-zsvhkg0xpx31cur0t5wvyfvo-4-0.jpg
12/24/2019 1:55:39 AM • Rancilio Coffee... • Answered on Dec 24, 2019
I have a rancilio Silvia. when I turn on the button for the steam wand, as it begins heating up it sprays steam into the water reservoir tank. I have tried descaling and backflushing. Any suggestions?
My guess is the steam wand is clogged with milk. This is a common problem. Try a pipe cleaner or something similar.
8/19/2019 8:28:15 PM • Rancilio Coffee... • Answered on Aug 19, 2019
Rancilio epoca e 2 group discharges steam out of safety valve what will cause this issue
Your pressure steam is more 1.8bar. Either pressustat defective or the safety valve
12/22/2018 8:22:33 PM • Rancilio Coffee... • Answered on Dec 22, 2018
Coffee Makers & Espresso Machines Logo
Popular Tags
10 questions posted
Top Rancilio Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Rancilio Coffee Makers & Espresso...
  • Rancilio Coffee Makers & Espresso...
Most Popular Question
rocky grinder spring pulls
  • Coffee Makers & Espresso Machines
