20 Most Recent Hotpoint 24 in. FDW60 Free-standing Dishwasher Questions & Answers
3answers
Where to put rinse aid in cdw10 dishwasher
Rinse aid makes dishes sparkle more as it improves their drying. The rinse aid container is situated on the inside of the door. You should fill the rinse aid container when indicator lights up on the container and the rinse aid indicator light on the control panel flashes. You can use simple vinegar as a rinse aid (white is best but apple or malt is fine). Adding rinse aid. To open the dispenser, turn cap anticlockwise. Take care when you pour in the rinse aid to avoid it overflowing. You can regulate the amount of rinse aid used by the dishwasher, move the adjuster which you will find under lid. The amount of rinse aid needs to be increased if the dishes appear dull or you can see circular stains. The amount of rinse aid needs to be reduced if the dishes are sticky or see white streaks. 4a742317-5f4e-4dc2-8132-3e560755df09.png You can choose from six different positions. It is normally set to 4.
9/1/2021 8:16:15 PM • Hotpoint 24 in.... • Answered on Sep 01, 2021
15answers
FDW60 flashing 'eco' light error
I had this problem and discovered it was due to a leak. The float switch attached to the bottom panel was operating. Pull out the mains plug, tip the machine on it's side (water will escape so get a mop ready), remove the bottom panel, 3 screws front and back, disconnect the connector from the float switch. Tape the connecter up out of the way and stand your machine back up. Try running it now. If you have a leak somewhere then you will get a puddle under the machine. If no leak, then I would suspect the float switch itself.
6/6/2021 7:49:42 AM • Hotpoint 24 in.... • Answered on Jun 06, 2021
2answers
Hotpoint FDW60 problem
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
2/22/2019 9:19:10 PM • Hotpoint 24 in.... • Answered on Feb 22, 2019
Lights flashing hotpoint fdw20 dishwasher
Heater elemnt is gone cheep fix , you will need to order this lower element
6/4/2018 6:13:33 AM • Hotpoint 24 in.... • Answered on Jun 04, 2018
3answers
How do i adjust the back foot on hotpoint lft114
If you look at the front of the dishwasher, below the door, you will see a red hexagon shaped nut. It requires an 8mm spanner or socket. Turn it clockwise to raise the back, anti-clockwise to lower. It works best if you can lift the back at the same time to take some of the weight off the foot.
9/26/2017 8:11:58 AM • Hotpoint 24 in.... • Answered on Sep 26, 2017
Hotpoint free-standing dishwasher AL01 error
Empty out th bottom tray - siphon it , use sponge, whatever, Then clean out the drain and snake out the tubing in there to get rid of any debris that is causing a clog in the works.
9/11/2017 4:53:34 PM • Hotpoint 24 in.... • Answered on Sep 11, 2017
0answers
0answers
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
573 questions posted
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
currys essentials dishwasher cdw60w10
  • Dishwashers
