20 Most Recent La Marzocco Linea Series Group 3 Espresso Machine Espresso Machine Questions & Answers
The boiler is contaminated, you will need to descale boiler and steam valves. Then rinse thoroughly about 5 times. The easiest way to check for this is to draw water from the tea spicket and check for smell and sediment. Something on the bottom of the boiler is being lifted when the machine fills and when it is heating. If there is a filter system on the line check to make sure it was changed recently.
La Marzocco... | Answered on Mar 21, 2018
Left side above the element.
La Marzocco... | Answered on Sep 12, 2014
The brew solenoid needs to be replaced.
It is possible that the thermostat on the grouphead needs to be reset.
Need group gaskets.
You can dowload one from LaMarzoccoUsa.com
La Marzocco... | Answered on Feb 19, 2013
there is two valves that can cause this one is called an anti-vac and the other is called an H/P valve (high pressure release valve or pressure safety valve) anti- vac valve is small and short. hope this helps
La Marzocco... | Answered on Feb 25, 2012
Then you will need to flush the boilers out and rinse, its easy, just takes alot of time. First turn the water supply and the machine off and let cool, then back off the screw in the knob a few turns and pull off knob. Then remove the screws holding the front panel to frame. There's about 5 of them. Note the valves under the boilers with the red or black handles. They are usually in the middle. Use this valve to remove the water in the boiler, then fill boiler and rinse about 3 times each. Then reassemble and you should be good to go.
La Marzocco... | Answered on Jul 20, 2011
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
La Marzocco... | Answered on Apr 15, 2011
There are 2 boilers on these machines, Which one are you having this problem with?
I might have the tank/boiler for the group heads.
If you remove the boiler, Replace O'rings and gaskets.
La Marzocco... | Answered on Jan 19, 2011
Replace or rebuild the Valve (behind the knob).
Turn off the machine and release the steam pressure.Before you take it apart.
La Marzocco... | Answered on Jan 15, 2011
Look at the bottom of the tank they have a red valve or a plug.
Once is off and cool down, Open the valve or remove the plug.
Open the steam valve (to allow the air in)to speed up the process.
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
La Marzocco... | Answered on Dec 16, 2010
Press spiral button and hold for 8 secs, lights will flash, then press button you want to program when you get correct volume press stop button. Some machines need a key to program them, check to see if there is a lock on the front of machine. If you have the model with the cronos pads you do not have to worry about a lock.
La Marzocco... | Answered on Aug 24, 2010
New machine? check the thermal reset on top of the left group head. Press the red button and see what happens.....
La Marzocco... | Answered on Aug 18, 2010
Coffee Makers & Espresso Machines Logo
36 questions posted
Top La Marzocco Coffee Makers & Espresso Machines Experts
Kelley Hopper
Vitally Alcher
Ngoro
Are you a La Marzocco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
La Marzocco Coffee Makers & Espresso...
  • La Marzocco Coffee Makers & Espresso...
Most Popular Question
marzocco linea need drain
  • Coffee Makers & Espresso Machines
