20 Most Recent
Tasco NV200 Monocular Questions & Answers
Degassed tube how to fix? repair?
Do you mean de-purged tube or de-gause tube? Image intensifiers are not like CRT where they have a gausing problem. If a spot is burnt into the image intensifier, it unfortuantely is permanent.
If you mean de-purged (gasless), this can be done by a reputable service/repair workshop with nitrogen.
Is there a place I can send this for repair?
There is a sneaky suspicion that Night Owl Optic has the same monocular. Now I will tell you these. This type of monoculars are manufactured in Red Star Country--Russia.
What seems to be the problem with you NV200 monocular? I can help you with your problems if you don't explain. stewbison
Need parts replaced or ater market.
Sorry Mike, but you haven't mentioned where you are?
Contact your local distributor for Tasco, they are normally pretty good. Look up Tasco online for contact details.
I BOUGHT THE TASCO NV-118.BUT I DONT KHOW HOW TO
First I am assuming you have the correct battery and it is installed. During day light you can check your scope. BUT FIRST DO NOT TURN THE SCOPE ON UNLESS THERE IS A LENS COVER IN PLACE. Most of these devices have a cover with a small peep hole which will permit checking out during the day. There should be a switch to activate the scope.
Then adjust the focus and magnification (front and eye) apertures. I hope this helps.
Good luck
How do you look though and see Star . Tasco 45-060525 does it need a light or something?
No, they only collect the light from the stars or the moon. First you have to be in a place with very little light pollution. I live in a city and haven't seen stars here for 17 years. Also you must let your eyes acclimatize to the dark.
In reality, this telescope will only be suitable for the moon, but the moon will fill the Object lens and show great detail. You may also see some planets if you can find them, but generally it turns a small speck of light into a larger speck of light. The International Space Station should also show well.
Here is your manual
https://manuall.co.uk/tasco-46-060525-telescope/
2/20/2022 1:23:10 AM •
Tasco Optics
Answered
on Feb 20, 2022
