20 Most Recent Universal Remote Control DISH Network UHF/IR Remote Control Questions & Answers
If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Universal Remote... | Answered on Jan 03, 2014
If you extend the small antenna that is on the back of the receiver by using a short cable and a barrel connector to get the antenna out of the entertainment center or out from the TV this will help alot
Universal Remote... | Answered on Aug 05, 2012
Himarieyvette2, my name is Mike Houston of DISH Network and I was going over yourpost and see where you're 4.4 IR/UHF Pro remote did not have a part. If youtake out the chip it is a two sided tab and will allow the remote to work forTV1 (Green side) and TV2 (Blue Side). I will send this link http://www.dishnetwork.com/SupportSection/setup-remoteto help with the steps to setup the remote.
Universal Remote... | Answered on Apr 07, 2012
Your question is not clear as to whether you want to program the remote to your TV or the DISH receiver. Here are steps for both if this has not been resolved already!
DISH RECEIVER::
1. Go to the room where the receiver is located. With the remote for THAT room press menu twice. (This will be the remote with the Green 1 on the bottom.)
2. Press and release the SAT button on the top left of the remote
3. Press and release the black and red record button 3 times
4. Look that the number next to remote address (secondary Remote address) has changed.
5. If not, start again.
TV::
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Universal Remote... | Answered on Aug 17, 2011
Hello, you may have gotten this resolved already, but here are some simple steps to help you out!!!!
Follow the link yo our website and you will be good to go with that remote real soon!!!
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Hope this helps!!
Becki Barned
Universal Remote... | Answered on Jan 28, 2011
Hello, this is Becki Barned, with DISH Network customer service. For this issue, since you have already replaced the remote and have the 5 foot coax cable on the antenna, then at this point, we would want to send a tech out for you. The technician can determine if this is an issue with the receiver box, or can set up a back feed for you. I can help you out with this issue further. You can e-mail me at becki.barned@dishnetwork.com .
Becki Barned
Universal Remote... | Answered on Jan 18, 2011
rpallot,
I have provided a link on how to program the DISH Network remote to the Samsung TV. The link is:
http://www.dishnetwork.com/SupportSection/remote-setup
A link for the remote codes is also included.
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
I hope this helps. If you have any other questions, please respond to this link.
Ray Calo
DISH Network
customz28,
Since you have tried several codes for your TV, the next procedure to attempt would be a power scan. I have provided a link with the instructions. The link is:
I hope this helps.
Ray Calo
DISH Network
ihatelittled,
Have you tried doing a power scan. If the codes we have listed for a certain brand of TV does not work, we perform the power scan. If it was working before but not now, the tech probably did the power scan. I have provided a link with instructions on how to perform the power scan. Here is the link:
Ray Calo
DISH Network
mandysnw,
Here is a website on how to program the remote.
http://www.dishnetwork.com/SupportSection/remote-setup. Not all remotes are compatible with all receivers. Plus if the receiver controls 2 TVs, there is a colored tab on the bottom of the remote that controls the remote functions. I hope this helps.
Ray Calo
DISH Network
jholsinger1,
It sounds like this is TV 1 that you are having this problem with the remote, is that correct? What has changed from when the remote was working till now? Was anything moved like the TV/receiver? You may have some type of interference with the UHF signal. Without getting more specific information, I'm generalizing the trouble shooting steps. Would you clarify if it's TV 1 or TV2. Please post to this site and I will respond back to you.
Ray Calo
DISH Network
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
Daniel Busa
Universal Remote... | Answered on Jan 16, 2011
There is a key in the bottom that has number 2 on it . Turn the key over to number1 and slide the button under the battery cover if needed from a to b or vise versa
Universal Remote... | Answered on Jul 06, 2010
Well, you could buy a vivitar universal remote on Amazon for 7.99 you would
Have two units and a manual. For a low price. Or post it in Craigslist Wanted Section and maybe Someone
Will let you copy theirs.
Universal Remote... | Answered on Nov 19, 2019
You have this backwards. The applicable code would be in a compatible remote control.
Universal Remote... | Answered on Nov 16, 2019
Televison & Video Logo
Popular Tags
25 questions posted
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Universal Remote Control Televison & Video
Most Popular Question
program remote
  • Televison & Video
