20 Most Recent Premiere Microscopes MRJ-01L Microscope Questions & Answers
Delta Optical Instruments, Inc.email; robin@deltaoi.com
Premiere... | Answered on Dec 24, 2010
sir,
There is two kind of eye-piece in microscope one is (push in ) and second one is tread mounted.
As per my i know you have push in eye piece.
See in side that cylinder where you are pusing in this eye piece there is two jows is there it resist to come in as well as when you take it out.that pressure of jows you should be increase.
your problems will short out.
INDRAVIJAY
Premiere... | Answered on Feb 19, 2008
If the digital microscope was designed to work with the earlier operational systems then you will need to replace the item. The only option is to check the manufacture web site in the hopes they may have updated the driver for windows 7 for your device.
Premiere... | Answered on Jul 01, 2011
a bunsen burner produces a small flame, it is used in laboratories for heating, sterilizing or combustion
Science &... | Answered on Dec 29, 2019
That is an autoclave and peoples life and health depend on it. Please contact the manufacturer at +39 0445 329811
Science &... | Answered on Sep 27, 2019
1. Always clean the slide. 2.Make sure that the fine and the coarse adjustment knobs do not scratch the slide by handling them gently.
Science &... | Answered on Sep 05, 2019
Turn it on and bring up the temperature. The pressure inside will increase as the temperature increases.
Science &... | Answered on Aug 19, 2019
The fault table is on page 15 of the following document.
http://frankshospitalworkshop.com/equipment/documents/autoclaves/service_manuals/Eschmann_SES2000_-_Service_Manual.pdf
Further support may be channeled through the distributor. As with many devices, it is suggested to have mainteance and repair done by personnel trained specifically in such for the devices. There is quite a bit of information in this manual one might wade through Page 28 lists error codes and error 2 listed refers to door open during cycle.
UK Customers Eschmann Equipment, Peter Road, Lancing, West Sussex BN15 8TJ, England. Tel: +44 (0) 1903 765040. Fax: +44 (0) 1903 875711. Overseas Customers Contact your local distributor. In case of doubt contact Eschmann Equipment.
Science &... | Answered on Jun 19, 2019
A User Manual for the Variscope Binocular 40x to 1000x microscopes is available from Amazon online:
http://www.manuallibrary.net/1475-40x-1000x-biological-binocular-user-manual.html
Science &... | Answered on May 19, 2019
Each letter refers to a cardinal direction North West East South, so press n e w n e w s.
Science &... | Answered on May 18, 2019
Manuals are available from PHC. Email service@us.phchd.com or call Technical Support at 800-858-8442 ext. 48299.
Try here:
https://www.optiboard.com/forums/showthread.php/8260-Lensometer
Science &... | Answered on Apr 26, 2019
You have a microscope with a camera in or on it? And the cord goes to a tablet computer? And "pulled up codes to download" means whet? "Pulled up"? "codes"? Did you "download"?
Most operating systems will use a graphics program to accept an image from a TWAIN device like a camera or a scanner. Perhaps you could use something like that.
I have used some different programs with cameras and scanners under Windows long ago (XP and Vista).
Science &... | Answered on Apr 18, 2019
Without a brand name and model number or any pictures, it is not possible to guess what you have, where the light is, what wires or switches might be on it.
Sometimes it is just a simple tightening of the bulb or cleaning of battery contacts to get it fixed.
GIVE YOU 1 GUESS IF YOU HAVE TO ASK HERE IT IS NOT YOU
Science &... | Answered on Mar 02, 2019
Premiere Microscopes MRJ-01L Microscope Logo
2 questions posted
Top Premiere Microscopes Science & Laboratory Experts
Pokinhas
Tom Chichester
Are you a Premiere Microscopes Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Premiere Microscopes Science & Laboratory
Most Popular Question
eyepiece objectives seem loose
  • Science & Laboratory
