20 Most Recent
Panasonic TC-P50S30 VIERA 50 Class 49.9 Diagonal S30 Series Plasma, Aspect Ratio 16:9, Native Resolution Number of Pixels 2073600 1920 x 1080, Moving Picture Resolution 900 lines, Shades of Gradation 6144 equivalent, 600Hz Sub-field Drive, 24p Playback 2:3, De Questions & Answers
I am getting a 14 blink code on my Panasonic TC-P50s30. Do you know what is causing this
Sounds like main digital board fault. 14 blinks denotes that. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/14/2016 4:21:37 AM •
Panasonic...
Answered
on Jul 14, 2016
14 blinks on my Panasonic TC-P50S30. Any Ideas?
11/20/2014 6:07:01 PM •
Panasonic...
Answered
on Nov 20, 2014
Will not turn on
We recommend you remove all HDMI cables from the TV and unplug the unit's power cord. Then wait 30 seconds and test a different electrical outlet. If the problem persists, we recommend you contact a local authorized servicer.
3/21/2014 4:54:22 PM •
Panasonic...
Answered
on Mar 21, 2014
Word Debug showing on Screen
We regret to inform you Panasonic TV's do not use any errors similar to Debug. We recommend you contact the source provider that the TV is connected to.
3/6/2014 5:51:39 PM •
Panasonic...
Answered
on Mar 06, 2014
Will not power up
If you have a direct power cord attached to the TV, try another cord like it and turn it on. That rules out the power cord, unless the power fuse at your home fuse box was flipped, or the power fuse to the TV was blown. Sometimes a Power surge or failure trips fuses or blows a fuse; so check them first. If all the Fuses or Circuit Breakers are working just fine, then the problem is more serious. The condition may now relative to either the Picture Tube and/or Projector Tubes, the power transformer, or damaged mainboard of the appliance. Any of these mentioned herein need a professional technician to check the circuitry for faults.
12/24/2013 11:45:23 PM •
Panasonic...
Answered
on Dec 24, 2013
Panasonic cf-19 Enter key not working
- Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM •
Panasonic...
Answered
on Jun 16, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM •
Panasonic...
Answered
on Apr 01, 2023
