20 Most Recent
Bamix Mono Mixer Questions & Answers
Blades
The blades pull straight off the shaft. If you look closely you will see a small notch on the blade that fits a tab on the shaft. This keeps the blade turning at the same speed as the shaft.
Anyway, pulling straight down on the blade should get it off. You might try boiling the tip in water to soften whatever gunk is holding it on. Be careful you don't burn your fingers when trying to pull off the blade after boiling it.
What are the Spring blades
they are the shaft end of your attachments. Tha part that fitd on the shaft. So you can squeeze them together with needle nosed pliers if they won't stay on the shaft.
