20 Most Recent Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions & Answers
Bunn Ultra 2 slushee machine not freezing
Hmm, that's definitely a problem! From what I understand, the Bunn Ultra-2 slushy machine is supposed to freeze evenly on both sides. So if it's only freezing on one side, there could be a few different things going on. It could be an issue with the refrigerant level, the solenoid, or the optical sensors. Can you tell me a bit more about the symptoms of the problem? For example, is the side that's not freezing completely warm, or is it just not getting as cold as the other side?
7/16/2023 10:41:18 AM • Bunn Margarita... • Answered on Jul 16, 2023
2answers
What does shaft maintenace due mean
It means your machine needs to have seals and bushings replaced. This maintenance should be performed twice per year to keep your Bunn Ultra 2 in working order. This is something you will need to call a technician in to do.
5/24/2016 11:20:56 PM • Bunn Margarita... • Answered on May 24, 2016
3answers
Reset password on bunn ultra 2
you will need to contact bunn for the master reset.
5/24/2016 11:12:13 PM • Bunn Margarita... • Answered on May 24, 2016
I have a Bunn Ultra 2 machine it was working fine last week I left it running and when I went and looked at it yesterday it had shut off and would not start up. I unplugged it from the outlet and it s
was it hot? the compressor may be overheated and went into shutdown until it cools. it's safety feature if the fan stops or if the airflow is blocked by too much dust. clean the filter, check the fan, and try again. if it's not hot, it's the transformer that powers the main circuit board.
5/10/2016 5:55:05 PM • Bunn Margarita... • Answered on May 10, 2016
It says sensor open
the sensor board is in the back behind the motor cowlings. open one up and the board is in front of the motor. check the wire harness to it, and check to see that it is not damaged. there should be a red and a clear sensor sticking up from it.
1/28/2015 4:41:42 AM • Bunn Margarita... • Answered on Jan 28, 2015
Oil coming out of back of machine
it isn't oil, it's old, syrupy slushie mix and dust. the only oil in the machine is inside the hermetically sealed (cannot open) compressor. you have a front seal problem. the shaft seal in the front inside the evaporator (steel tube), and the cup-shaped seal between the auger and the evaporator. slush is getting inside the shaft tube and dripping through the inside rear of the machine. replace the seals, lube with a food-safe lube and refill.
1/3/2015 10:42:07 PM • Bunn Margarita... • Answered on Jan 03, 2015
Left side of Bunn Ultra "ice" mode is in lower case but right side "ICE" mode is in upper case?
upper case means it is still trying to slush. lower case means it has reached designated slush thickness
11/27/2014 4:39:38 AM • Bunn Margarita... • Answered on Nov 27, 2014
Left side of Bunn Ultra 11 "ice" mode is in lower case and freezes but right side the ice mode is in upper case and does not freeze. What is the problem?
chances are the refrigerant solenoid valve for that side is bad. replace the coil
9/12/2014 4:02:42 AM • Bunn Margarita... • Answered on Sep 12, 2014
Bunn ultra 2 says hold ultra button
the words ultra, gourmet, and ice above the display are buttons
9/8/2014 3:39:59 AM • Bunn Margarita... • Answered on Sep 08, 2014
Bunn ultra 2 where is the ultra button
the words ultra, gourmet, and ice above the display are buttons.
9/8/2014 3:38:05 AM • Bunn Margarita... • Answered on Sep 08, 2014
Bunn won't freeze the drink, the drum freezes and
clean the filter and condenser coils, leave at least 6 inches of space for it to breathe
9/8/2014 3:34:39 AM • Bunn Margarita... • Answered on Sep 08, 2014
I have a 2 hopper bunn ultra 2, both sides are
the mix is too rich. add some water to each side. it freezes based on torque, not temp.
9/8/2014 3:32:45 AM • Bunn Margarita... • Answered on Sep 08, 2014
The selenoids of my bunn ultra 2 still working all night upon I turn off the machine
hold down the "gourmet" button above the display for 5 seconds to get into the menu. scroll through (gourmet button) until you get to "reset" and select yes.
9/8/2014 3:27:22 AM • Bunn Margarita... • Answered on Sep 08, 2014
Paddle does not turn
What does the display say? the shaft has an optic sensor. if the shaft pins or the sensor board are broken, it'll say sensor error. if the torque springs are broken, replace the shaft.
9/8/2014 3:23:13 AM • Bunn Margarita... • Answered on Sep 08, 2014
Bunn ultra-2 slushi machine not icying up
Make sure it's on ice, not chill or off. clean the rear filter and make sure there is at least 6 inches of space behind the machine for it to breathe.
9/8/2014 3:22:42 AM • Bunn Margarita... • Answered on Sep 08, 2014
Bunn ultra-2 not icying up
make sure it's on ice, not chill or off. clean the rear filter and make sure there is at least 6 inches of space behind the machine for it to breathe.
9/8/2014 3:22:25 AM • Bunn Margarita... • Answered on Sep 08, 2014
Kitchen Appliances - Others Logo
91 questions posted
Top Bunn Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Bunn Kitchen Appliances - Others
Most Popular Question
reset password bunn ultra 2
  • Kitchen Appliances - Others
