20 Most Recent Tasco 750 Monocular Microscope Questions & Answers
Amazon has used ones for about $25. New they are not worth that much more. They are designed more as a toy, then a real microscope.
Tasco 750... | Answered on Mar 12, 2019
contact tasco.
try ebay for a month (search various combinations of keywords). notify by email.
21.january.2015
Tasco 750... | Answered on Aug 23, 2015
I have a instruction book....I can photocopy it for you if you wish
Tasco 750... | Answered on Jul 04, 2013
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
Tasco 750... | Answered on May 19, 2013
You will need to focus in on the slide. There should be 2 1" diameter knobs on either side of the stand, and just to the rear. Those knobs control the height of the stage (where you slide sits). Slowly raise or lower while looking into the eyepiece. At some point something should be see, if the microscope is working properly.
Sometimes it is easiest to start with the lowest magnification. On the outside of the objective (little lenses hanging down that can be rotated) there should be some numbers written on them (usually 4, 10, 40). Those numbers reference your magnification. If you multiply that number by the eyepiece (10) magnification, you will get your total magnification, so start out with your 4x. It will give you the largest field of view, so it is great for finding whatever it is that you are looking for on your slide. It is also the easiest one to get focused. The higher you go in magnification, the smaller the field of view, thereby the more difficult it is focus in on your sample.
Tasco 750... | Answered on Sep 05, 2011
sometimes when a battery causes corrosion inside something, you can clean off the springs or contacts where the battery goes. if i can, when that stuff happens i use sandpaper or something like that to clean the contacts. you cant always get sandpaper where you need it though. just try to find something to like scrape stuff off if its on there
Tasco 750... | Answered on May 01, 2010
Tasco 750 Monocular Microscope Logo
Popular Tags
32 questions posted
Top Tasco Science & Laboratory Experts
Ekse
 Brian Main
Brian Main
 Mikey
Mikey
Are you a Tasco Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Tasco Science & Laboratory
Most Popular Question
picked up bushnell 1200 power microscope
  • Science & Laboratory
