20 Most Recent
Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Questions & Answers
Have a 2000 Chevy s10 pick up (flex fuel)replaced
Well, First turn the ignition to ON and listen for a faint hum.
If you don't hear anything. The pump is not running. (2) Have your mechanic check the wires to the fuel tank.(under the vehicle) and see that the pump is getting power. If no power, look around battery and wire connections. Hope that helps.
3/2/2018 2:22:10 AM •
Minuteman...
Answered
on Mar 02, 2018
99 chevy s10, fuel pump?
This happened on mine and at first i had 4v at the harness going into the tank then it eventually went to 0v im prettysure thats why the pump burnt up but anyway after much head scrtaching i tied into the ground wire coming out of the tank and grounded it to the frame and the truck is running fine there vehicles are known for bad wire looms
3/7/2011 5:25:48 PM •
Minuteman...
Answered
on Mar 07, 2011
I'm working on a friends
The condition for setting a P1351 is the when the PCM (Powertrain control module) has ignition control (EST Enabled) and the RPM has dropped below 250. So I’m not sure if chasing this code is going to take us anywhere. Because the PCM is just reporting the obvious, as in the PCM is trying to keep the engine running but it still stalled. Thanks PCM but thanks for nothing we know the engine has stalled, what u have here is no injection of fuel into the engine by the Powertrain control module, if u put a test light on the injectors u should have one wire that is hot all the time with the ign key turned to on, if u don't check for a blown ECM 1 or ECM 2 fuse in the under hood fuse box, they are clearly marked, if the fuse is blown then you have a shorted engine harness, u will need to remove the harness and look for rubber through bare wires, this is common near the places the harness goes over or touches the engine parts.if you do have 12 volts to the injectors harness connector then you may have a PCM/Powertrain control module problem, the injectors are grounded by the PCM in sequence of firing order, u have one or the other of these conditions, this assumes that pressurized fuel (approx 55-60 PSI) is avil to the injector inlet.
10/10/2009 4:01:40 AM •
Minuteman...
Answered
on Oct 10, 2009
How to replace battery
Close the power Open UPS screw Then remove connection & batteries. set the batteries conect + RED - any colour close Charge one hr. start work.
from vinod
4/24/2008 2:33:25 AM •
Minuteman...
Answered
on Apr 24, 2008
How i can get Erasmus Mundus Scholarship?
1. RESEARCH: FIRST, RESEARCH THE ERASMUS MUNDUS PROGRAMS AVAILABLE AND FIND THE ONE THAT SUITS YOUR FIELD OF STUDY.
2. APPLICATION: FILL OUT THE APPLICATION FORM COMPLETELY AND ENSURE YOU PROVIDE ALL REQUIRED DOCUMENTS.
3. ACADEMIC RECORDS: MAKE SURE YOUR ACADEMIC RECORDS ARE STRONG AND HIGHLIGHT ANY RELEVANT EXPERIENCE OR ACHIEVEMENTS.
4. LETTERS OF RECOMMENDATION: GET STRONG LETTERS OF RECOMMENDATION FROM PROFESSORS OR EMPLOYERS WHO KNOW YOUR WORK WELL.
5. ESSAYS: WRITE STRONG ESSAYS THAT SHOWCASE YOUR PASSION, MOTIVATION, AND GOALS FOR STUDYING ABROAD.
6. LANGUAGE PROFICIENCY: IF REQUIRED, TAKE LANGUAGE PROFICIENCY TESTS LIKE IELTS OR TOEFL AND SCORE WELL.
7. INTERVIEWS: BE PREPARED FOR INTERVIEWS IF NEEDED AND SHOW YOUR ENTHUSIASM FOR THE PROGRAM.
8. DEADLINES: MAKE SURE TO SUBMIT YOUR APPLICATION BEFORE THE DEADLINE.
I have a problem with
dear ap inpage ka ye version download karen or is article ko parhain Apko Zaroor Faida hoga.
https://infotechinurdu.blogspot.com/2017/09/how-to-download-inpage-urdu-inpage-free.html
Panamax 1000+
Can you please advise what is the panamax 1000 the only panamax I now is for headaches!
