20 Most Recent
Buffalo Technology Buffalo MiniStation Plus HD-PNTU3 1 TB External Hard Drive - Red USB Questions & Answers
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
2/25/2016 11:14:31 PM •
Buffalo...
Answered
on Feb 25, 2016
My buffalo hd pntu3 hard disk is encrypted using
In the software Secure Lock Manager Easy is a tab "Setting the Encryption mode" Pressing "Releasing encryption mode" will remove the encryption. Make a backup of the data before please.
11/5/2013 9:32:58 AM •
Buffalo...
Answered
on Nov 05, 2013
Any computer or laptop cannot read or detect my buffalo external HD.every time i plug it in, i would hear a sound that indicates it is plugged in yet, when i check my computer, i cannot find it there.
If You have a yellow Triangle,you know the one you deleted, it means that there is no driver, or the wrong driver is installed for those plugins! then I would say that You need drivers for your USB plugins! If you have the drivers disk that came with your PC/laptop, reinstall them, or go online to the maker of your PC/laptop and get the drivers from them! after reinstalling USB drivers. If it still is unrecognized,try a different USB cable form hard drive to PC.
4/18/2017 4:02:40 PM •
Buffalo...
Answered
on Apr 18, 2017
Forgot external drive password
If there isn't any data on there that you need, you can try formatting it. If you didn't make a recovery disk, or make any note of the password, formatting may be the only solution.
2/18/2015 8:53:04 PM •
Buffalo...
Answered
on Feb 18, 2015
How do i recover serial number on buffalo ministation HD-PNTU3
Load Nas Navigator2 and it will bring up it's built-in web page. When it finds it it will display it's properties inc. serial number. The default user is 'admin' and the password is 'password' as default.. unless you have changed that. If that doesn't work look to Buffalo Support as they are very good.
10/19/2014 6:26:10 AM •
Buffalo...
Answered
on Oct 19, 2014
Buffalo HD PCU2
check weather it get connected with other system and other operating system. Also check your data cable
7/21/2014 12:25:55 PM •
Buffalo...
Answered
on Jul 21, 2014
Clicking noise
Clicking sounds are never good in a hard drive. It always indicates some sort of hardware failure or mechanical problem.Here is a guide on how to initially diagnose your issues with hard drive problems.
Diagnosing Data Recovery
Ultimatley you need to assess the value of the data on the drive in order to determine if you need recovery help. If the data is valuable then you will want to consult a professional that has the proper environment to safely reocver your data from the failing drive. Every move you make will ultimately determine or lesson the chances for successful recovery.
5/21/2014 3:38:38 AM •
Buffalo...
Answered
on May 21, 2014
My device is not being recognized
It looks like Linux Mint is not a supported OS.
Buffalo Americas
Only the following are supported:
Windows 8 (32-bit/64-bit), Windows 7 (32-bit/64-bit), Windows Vista (32-bit/64-bit), Windows XP, Mac OS X 10.5 or later
The Linux Mint Dev Team may be working on a solution, but this is not something Buffalo will help you with.
4/19/2014 3:02:01 PM •
Buffalo...
Answered
on Apr 19, 2014
