20 Most Recent
Canon CANNON IR 3530 COPIER FOR 220 VOLTS ONLY Questions & Answers
How to solve error code E000000 - 0001
The temperature of the fixing assembly is abnormally high.
While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
E000732 0001 error in ir 3530 how can i solve
Official instructions from Canon are these, try if it works for you:
Solution 1:
- Check all the cables outside of the printer: they must be plugged, especially between the differents elements of the copier:
- Solution 2:
- Check all the connectors on the main board.
- Solution 3:
- Unplugg and replugg all the leads between the boards and modules
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
What is solution forCode 225 in Canon Fax 150?
1. If you have a spare cartridge, try installing it to the printer replacing the one that is currently installed. Restart the unit. Does the error still appear?
2. Did you just install a new replacement? If yes, make sure it is not faulty as it may result to the same error. Or, check the chip reader (the sensor coupled with the chip tag from the cartridge) inside the unit to see if there's any problem.
3. There's also a possibility that it is a cable problem. If you can borrow a compatible cable for your printer then it is good, otherwise you have to buy a new one. But before you get a new cable, try testing the other solutions first to avoid any unnecessary expense.
4. Turn the unit ON, press and hold Reset button for exactly 6 seconds (you don't need a timer for this - just kidding), then release. After this, you need to restart the printer by unplugging it from the power source for a minute before turning it back ON.
5. If nothing's really working, turn the printer OFF then ON followed by lifting the scanner lid. It may sound absurd but it's worth a try.
6. Blame the scanner lamp. This one's a little tricky and requires some technical skills as you have to remove the glass from the scanner and tweak the two white plastic rulers. You only need to do this if those rulers dropped out.
Display touch is very hard
my printercanon ir 3530 insaid disply was rain water in said but how to open and cleen the disply bord tuch screen
