20 Most Recent
Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL USB 9600X2400 6.0IPM * 3747B002 Questions & Answers
I need to install the printer and do not have disc -- need device and was told I could download not sure what to do
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp-series/pixma-mp560/!ut/p/z1/hZBPU4MwEMU_iweOsDtgsXhLqR1wQKfVqTEXB5wAUUgyIRX10xu1F__Vve2-35t9u8CAApPVk2grK5SsetffsviuXGfzLE-xuFyFZ0jK621RRnmEmxhu_gOYk_GPIgjnH8ABv0sQmjItW2C6sp0vZKOAaiOk5WYEOu60Vsa6-eMDt_5eADpof-RGcIdo8TxU_qBnMbq87OtG3CQnSOJlnCUXC8zXsx_AdnHsgGSZRuHqPfUeOHxU26v6839E1tHcpTe84YabYGfcuLNWj6ceejhNU9Aq1fY8uFeBkB7-ZurUaIF-Z0EP9LUgzVXus_plIkdvNVbgyQ!!/dz/d5/L2dBISEvZ0FBIS9nQSEh/
Download Windows 7 driver and right click on installion icon and run compatability select windows 7.
Right click and select run as administrator.
This will solve the problem of installation on Windows 10
Canon pixma mp560 printer error b200
Leave the cover open, turn off, before it off, hold the reset &
Start (color) until it completely off, then turn it back on. it works
for me, good luck folks
Printer head problem
Replacement of the printer head is recommended but some times its not worth the printer value.
B200 error on canon pixma MP560 inkjet printer
Try this. Disconnect printer from computer
2. re- connect after a minute.
3. from tools menu, clean cartridge.
4. now allign cartridges from the same tool menu.
5. complete allignment process as directed.
6.now try test print.
Canon mp560 b200 error
if you want to know what this is the error code is related toclick start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message detailsif its driver related
Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow question / exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope it helps
Canon Pixma 560 won't turn on
make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver
hope this helps
