20 Most Recent Hoover HCA300FK Top Freezer Refrigerator Questions & Answers
2answers
Our fridge / freezer is freezing everything,
replace thermostat
2/23/2016 9:12:42 PM • Hoover HCA300FK... • Answered on Feb 23, 2016
0answers
Temp will only get to 12 degrees at bottom of the
either your camper vent door between the refrige and freezer isn't closing or is frozen wide open so as not to shut off cold air inrush from the freezer or the compressor cold control is locked and won't let the compressor cycle on and off as necessary,or a combination of both of these issues
7/19/2010 3:12:29 PM • Hoover HCA300FK... • Answered on Jul 19, 2010
2answers
What number should the fridge be on also should
Hi there buy a fridge thermometer to be energy efficient freezer should be no more than minus 18 degrees and the fridge should be no more than 6 degrees Hope this helps Best Regards ALex PS I brought a thermometer off ebay for $6.00 works well, electrical bill has dropped more than this
8/10/2009 8:47:26 AM • Hoover HCA300FK... • Answered on Aug 10, 2009
I have a hoover fridge model HE505UF am chasing the freezer basket and the fridge lamp anyone knows where I can get one
Most spares are to be found here; https://www.espares.co.uk/browse/at1084ma107/fridges-and-freezers/hoover
8/17/2023 6:13:58 PM • Hoover... • Answered on Aug 17, 2023
Hoover HFLE54XK Fridge. Condensation in my Hoover under the counter fridge.
Goodness, that is tiny even for a UK fridge! https://www.rjelectrics.net/product/hoover-hfle54xk-freestanding-under-counter-larder-fridge-silver/ The problems are two-fold
  • Your fridge is basic and has no circulation fan.
  • The air in your home is too humid.
Try something like this from Screwfix UK to soak up and condense the moisture. Best advice though is get a new one and sell that one on Marketplace or Kijiji. https://www.screwfix.com/c/heating-plumbing/moisture-absorbers/cat14640001 ..
8/2/2023 9:28:19 PM • Hoover... • Answered on Aug 02, 2023
Hoover blade brush won't rotate. brush clean, belt good
If the brush on your Hoover Blade vacuum cleaner won't rotate, there are a few things you can check to try and fix the issue:
  1. Check for obstructions: Check the brush roll for any obstructions like hair, string, or debris that might be wrapped around it. Remove any obstructions you find.
  2. Check the belt: Even if the belt looks good, it might be stretched or damaged. Check that the belt is tight and not slipping. If the belt is stretched or damaged, replace it with a new one.
  3. Check the motor: The brush roll is powered by the motor, so if the motor is not working properly, the brush won't rotate. Check that the motor is working by turning on the vacuum and listening for a humming sound. If you hear a humming sound, the motor is working. If not, there may be an issue with the motor that requires professional repair.
  4. Check the brush roll bearings: If the bearings on the brush roll are worn or damaged, it may cause the brush to stop rotating. Try rotating the brush roll by hand. If it doesn't turn smoothly, the bearings may need to be replaced.
If none of these solutions work, it may be best to take your Hoover Blade vacuum cleaner to a professional for repair.
5/1/2023 6:46:37 PM • Hoover... • Answered on May 01, 2023
Hoover HV9 9H1075 Fridge. How to change the LED light please?
Question edited for clarity. You may be able to repair the board. If not, the whole module is replaced. https://www.google.com/search?q=Hoover+HV9+9H1075+Fridge.+replace+LED+light
2/7/2023 6:29:09 PM • Hoover... • Answered on Feb 07, 2023
Loud buzzing from Hoover Fridge.
You are not alone! https://www.google.com/search?q=hoover+hsc574s+buzzing+noise The condenser coils are underneath and it the perfect place to attract fluff, especially if you have animals. On mine, you open the bottom door and pull off the kick grill. There is also a panel on the back at the bottom that hides the compressor. That is an easier place to get the vacuum cleaner crevice tool in. You buzzing may be overheating, but it may also be a sign of impending failure.
Cleaning Your Fridge or Freezer - Advice Centre - Hoover ...
https://service.hoover.co.uk > advice-centre > cleaning-... Routine cleaning tips. Your fridge freezer should be regularly cleaned to ensure good hygiene practice. You should take care to remove obvious food debris, ...
1/22/2022 7:29:26 PM • Hoover... • Answered on Jan 22, 2022
How to change led light in hoover fridge
remove plastic cover then remove bulb
2/14/2021 4:28:23 AM • Hoover... • Answered on Feb 14, 2021
My 15 years old Hoover contour both freezer and fridge not cold enough even I switched on to the max
Refrigerator: Freezer not cold enough. Defrost system problems, dirty condenser coils, fan failures, leaky door gaskets or control problems can lead to your freezer not getting cold enough. ... The frost buildup blocks cooling air paths through the evaporator so the freezer doesn't cool well. https://www.searspartsdirect.com/diy/symptom/refrigerator-repair/1234589/freezer-not-cold-enough/ref0002
5/14/2020 10:16:10 AM • Hoover... • Answered on May 14, 2020
How old is my orchid Hoover 400litre fridge?
The Hoover Orchid is actually a rebadged Phillips Fridge. It would be over 20 years old now. I used to fix these in the mid to late 90,s
9/23/2019 2:14:36 AM • Hoover... • Answered on Sep 23, 2019
Hoover Nextra Class A Fridge is not cold. Ice
Check out these tips...they can help you figure out what is going wrong withyour refrigerator \\
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
11/8/2018 2:57:50 PM • Hoover... • Answered on Nov 08, 2018
Hoover HCA300FK Top Freezer Refrigerator Logo
Popular Tags
14 questions posted
Top Hoover Refrigerators Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Refrigerators
Most Popular Question
number fridge also
  • Refrigerators
