20 Most Recent Sansui TVS2750 27" Questions & Answers
Dark screen
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
7/16/2017 1:32:26 PM • Sansui TVS2750... • Answered on Jul 16, 2017
SANSUI SCS21SDR
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view. http://electronicshelponline.blogspot.com/
1/22/2014 1:41:27 PM • Sansui TVS2750... • Answered on Jan 22, 2014
Local channels wont come in I have all of the upper channel but no 3,8,30,gone?
sounds like one of the bands of channels in your set's tuner is now bad.
12/13/2012 9:22:49 PM • Sansui TVS2750... • Answered on Dec 13, 2012
What fuse to use
Use a 3.5 Amps 250V rated fuse.
7/26/2012 1:27:38 PM • Sansui TVS2750... • Answered on Jul 26, 2012
Hi there My Sansui TV screen
It is an indication that you have a problem on the vertical section on the main board. The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
1/7/2011 10:07:38 AM • Sansui TVS2750... • Answered on Jan 07, 2011
Will not turn on and off
If totally dead check plug fuse, if you get a standby light ,and it wont come on by remote then , it could be power supply a problem, could be capacitors leaky in power supply. not a job for the novice,
pete
11/15/2010 10:49:34 PM • Sansui TVS2750... • Answered on Nov 15, 2010
TVS2740B, how do I switch from TV to Video Input manually?
going to have to get a universal remote with input button on it, or tv/vcr button, had same problem!!
1/4/2009 9:28:02 PM • Sansui TVS2750... • Answered on Jan 04, 2009
Sansui Mod. TVS2745, May 2002
I'm sorry. No.
10/23/2008 12:21:17 AM • Sansui TVS2750... • Answered on Oct 23, 2008
My jensen tv has no color when hooked up to playstation2 (modelts2750j)
same with my ps2
9/3/2008 10:43:03 PM • Sansui TVS2750... • Answered on Sep 03, 2008
2answers
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
8/24/2007 2:00:27 AM • Sansui TVS2750... • Answered on Aug 24, 2007
Sansui 27"
I think you're on the right track. It sounds like the problem is in the horizontal deflection circuit or pincushion circuit.Maybe a bad solder connection or a resistor burned loose from the circuit board. Stargazer
4/24/2007 5:49:31 AM • Sansui TVS2750... • Answered on Apr 24, 2007
Can I program a Sansui television?
It depends what you want to program it into?
How Do I Program My Sansui?
Techwalla https://www.techwalla.com > Tech Support > How To Turn on the television using the "Power" button on the remote control. Press the "Menu" button on the remote to bring up the main menu for your Sansui. Use the ... ..
2/20/2024 5:45:40 PM • Sansui Televison... • Answered on Feb 20, 2024
My Sansui TV has no remote and cannot access wifi
SmartAviator, no other information is required as the question is concise as it is.
1/7/2024 11:58:49 AM • Sansui Televison... • Answered on Jan 07, 2024
Sony PlayStation PS4. How to hook to my 2009 19 inch Sansui television please?
Question edited for clarity. For a definitive answer, the television model number should have been added to check specs.
Can't get video to work on tv. Sansui HDLCD19WB and not ...
JustAnswer https://www.justanswer.com > TV Problems Sep 28, 2018 - Can't get video to work on tv. Sansui HDLCD19WB and not sure of age trying to hook up PlayStation. Menu works, no just - Answered by a ... 1 answer · Top answer: Okay, that is likely the problem here because HDMI will not convert directly to AV red, white ...
Can I connect a PS4 into any LED TV?
Quora https://www.quora.com > Can-I-connect-a-PS4-into-any-... May 3, 2018 - Usually PS4 is connected to a HD TV or 4K TV through HDMI cable which is the most obvious method. PS4 console has HDMI port just for the obvious ... 4 answers · Top answer: Hey man thanks for the request The ps4 console is connected to the tv through an HDMI cable ... Will a PS4 work with any TV? - Quora 9 answers May 26, 2018 Can a PS4 work with a 1366x768 TV (vu 32-inch ... 4 answers Nov 22, 2017 Will PS4 slim work with any TV? - Quora 6 answers Apr 5, 2017 Are Sansui 4k LED TVs any good? How do they ... 4 answers Nov 26, 2016 More results from www.quora.com
12/17/2023 11:11:14 PM • Sansui Televison... • Answered on Dec 17, 2023
2answers
Am connecting a SANSUI TV to a Dish Hopper. No problem with HDM1, but where to land the HDM2 cable at the Hopper?
I have never heard of a dish hopper before, but this tells you how to set them up. A Sansui is probably not the best choice as they are cheap and nasty televisions. https://www.google.com/search?q=Dish+Hopper+connections ..
11/4/2023 11:50:33 PM • Sansui Televison... • Answered on Nov 04, 2023
Sansui TVS2750 27" Logo
17 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
sansui tv screen
  • Televison & Video
