20 Most Recent Sansui COM312AD 13" TV/VCR Combo Questions & Answers
On the initial set up screen choose air on the tuner select line then do an automatic channel search.
Sansui COM312AD... | Answered on Feb 18, 2016
These are the codes to check with Sansui brand TVs. 1052 1061 1203 1157 1091 1075 1173 14231140 1032 1051 1337 1237 1209 1079 1232 1287 1203 1258 1335 13391340 1375. If you wish to get more codes, and set-up proceedings to many other popular remote controls, check these links.http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Sansui COM312AD... | Answered on Jul 11, 2013
GOOGLE este numero de modelo
Sansui COM312AD... | Answered on Mar 28, 2012
Hello
You hven't given any specification of the remote control you have. Yet I hereby send you universal remote codes for Sansui herewith.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit codes to check with are:
0135 0310.
Four digit code for Sansui TV/VCR cobo is:
0310
  1. .
Sansui COM312AD... | Answered on Nov 02, 2011
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Sansui COM312AD... | Answered on Feb 09, 2011
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Sansui COM312AD... | Answered on Jan 27, 2011
Did you check the fuse inside the plug on the 12volt cord?
Sansui COM312AD... | Answered on Feb 06, 2009
I'm sorry, but this tv is not digital. You might be able to use an inverter that converts 12volts DC to 120volts AC to power a digital converter box.
Sansui COM312AD... | Answered on Nov 08, 2008
I'm sorry, but you need the original remote or a universal that will activate the input on the tv.
Sansui COM312AD... | Answered on Nov 07, 2008
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
Sansui COM312AD... | Answered on Feb 19, 2008
I get all my firmware updates from this site
Home Page
Sansui Televison... | Answered on Nov 14, 2019
I'm guessing a power surge from the returning power burned something up. You should have all your electronics plugged into surge protectors at a minimum. The best protection is a UPS (uninterruptable power supply).
Sansui Televison... | Answered on Nov 13, 2019
i'd like a nice coed too but young women don't usually go for old worn out men
Sansui Televison... | Answered on Nov 10, 2019
Already answered on your earlier post/
Short answer, analog probably not possible.
Maybe if you get a digital antenna and you have stations in your area.
Sansui Televison... | Answered on Nov 03, 2019
Sansui COM312AD 13" TV/VCR Combo Logo
16 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
need code remote control
  • Televison & Video
