20 Most Recent Sansui COM3101 13" TV/VCR Questions & Answers
Have a rca remote and a spongebob tv and cant get it to program
027,018,038,093,033 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
3/27/2013 5:00:43 PM • Sansui COM3101... • Answered on Mar 27, 2013
2answers
Using an RCA universal remote
WIKIPEDIA has this link for your situation: How to Program an RCA Universal Remote Without a "Code Search" Button http://www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button I think that should help with your situation. Let me know if it does not.
3/27/2013 3:50:37 PM • Sansui COM3101... • Answered on Mar 27, 2013
4answers
Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
what is the cost of picture tube for model SV 2102
10/24/2012 10:25:21 PM • Sansui COM3101... • Answered on Oct 24, 2012
2answers
I need the manufacturer's code
The remote control that you use for your Comcast box will not operate all functions of the TV sice its a combo model. Your best bet is to purchase a universal remote control from the following website. There are 3 different versions of your TV's model number so make sure you choose the correct one for proper operation. Good luck
http://www.remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=13116091656740
11/18/2011 11:26:36 PM • Sansui COM3101... • Answered on Nov 18, 2011
I have no remote and
With the set switched on pull it's AC plug out of the socket then switch the manual button on the set to Off.
Leave for 10 minutes, plug back in, switch on and see how it is.
9/22/2011 9:37:02 AM • Sansui COM3101... • Answered on Sep 22, 2011
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
9/10/2011 5:40:46 PM • Sansui COM3101... • Answered on Sep 10, 2011
Screen becomes small in breadth
I am assuming that "breadth" means the vertical height. It is a common problem, associated with 2 components. Either the Vertical Output IC and/or the vertical yoke coupling capacitor. Either of these can cause a similar problem. If you are handy and have the proper equipment, you can do it yourself. Locate a schematic, locate the Vertical output IC, order the replacement IC from a parts distributor like MCM Electronics or equivalent and replace it. If you are not handy, this should be under $100.00 for a professional repair at any TV repair shop.
12/25/2010 4:20:21 AM • Sansui COM3101... • Answered on Dec 25, 2010
TV does not respond to remote. Remote tests OK and
Hello
Your TVs infrared sensor is not taking the infrared pulse from your remote control. It may be faulty. It is fitted on the ciruitboard just behind the infrared sensor window. It is three pin component, and can be resoldered out from the circuit board. There are differnt numbers of infrared sensors, used in Sanyo televisons. You just open the tev, draw the circuit board out of it, and you can see black tree leged element soldered to the circuit board. Just resolder it out from the board, and go for a same type and number. Replacing it will solve your problem. Before desoldering it out, check its present soldering for any fault. Check the voltage at the pin number 1 of that sensor. It should be around 5VDC. If it is there not check for any resistance for break.
If all other functions are working with its front control panel, the 5vDC voltage mentioned above will be there, since system control IC needs this voltage, and from which the supply to the infrared sensor also is given. It is a most common fault in all TVs. OK.
12/6/2010 10:07:19 PM • Sansui COM3101... • Answered on Dec 06, 2010
How do i program my set to record a show? the
Go to menu, go to record, set date, start time, stop time, channel, then press exit.
9/17/2010 5:15:10 PM • Sansui COM3101... • Answered on Sep 17, 2010
I lost my remote and i bought a universal and it
See OrionAmerica.com to purchase an original remote!
6/19/2010 6:02:20 AM • Sansui COM3101... • Answered on Jun 19, 2010
I need the tv code to program my remote
Try this, 200, hope this helps..
3/20/2010 8:00:00 PM • Sansui COM3101... • Answered on Mar 20, 2010
3answers
I need a remote for my 13 inch television with a
Hello, this should be the correct model number of the remote: 07660CG020
Here is an ebay auction for one:
http://cgi.ebay.com/07660CG020-REMOTE-CONTROL-for-TV-VCR-Combo_W0QQitemZ120378205047QQcmdZViewItemQQptZLH_DefaultDomain_0
8/24/2009 1:12:38 PM • Sansui COM3101... • Answered on Aug 24, 2009
5answers
Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
4/29/2009 6:51:26 PM • Sansui COM3101... • Answered on Apr 29, 2009
Menue access
Click MENU on the remote...it should work
3/31/2009 8:44:38 PM • Sansui COM3101... • Answered on Mar 31, 2009
Audio muffled when playing back video tape
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
2/6/2009 3:08:31 PM • Sansui COM3101... • Answered on Feb 06, 2009
Screen turns black except for one inch around the outer edge
Use the tv/cap/text button to turn off the text box function of the closed captioning.
2/6/2009 1:30:16 AM • Sansui COM3101... • Answered on Feb 06, 2009
On screen message "DEW"
DEW on the screen means that there is moisture in set. Leave the unit on for several in a warm dry place. The heat from the picture tube will help dry out the set.
1/7/2009 12:25:34 AM • Sansui COM3101... • Answered on Jan 07, 2009
Need access code for remote control
Sansui Codes-191-208
12/25/2008 4:55:20 PM • Sansui COM3101... • Answered on Dec 25, 2008
Sansui COM3101 13" TV/VCR Logo
38 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
sansui sv 2102 got some problem please
  • Televison & Video
