20 Most Recent
Hoover AAA160 Front Load Washer Questions & Answers
Hoover Nextra No Lights Not working
please check the fuse in the plug it should be13 amp it has no doubt blown after replacing it and happens again there might be a problem with the heating element it might be faulty or ruptured due to short circuit in the element eric
Why my hoover is not drying very well its an automatic machine
Make sure the drain line isn't clogged with a sock or something small. Some models have a lint trap, usually at the front, that requires periodic cleaning. If the trap or drain line is partially obstructed, a first load's rinse water won't drain completely in the lowest part of the vertical drum you can't see. If this doesn't solve your issue, there is a pump problem.
Hoover AAA 160 Washer error code 4
PLEASE INSPECT DOOR BOOT (RUBBER DOOR GASKET) IF NOT CAN BE FILL VALVES NOT COMPLETELY TURNING ITSELF OFF ,,, IF ALL LOOKS GOOD REPL/ PRESSURE SWITCH
Hoover oph 614 on the front at the bottom ther is
Had the same problem today. Found a very small piece of lint/fluff in the sealing groove of the filter socket. Removed this with an orange stick & touch wood the floor is dry again.
Do hope this helps
