Maxent Televison & Video • Uploaded on Sep 29, 2013
If you don't have necessary tools and test instrument and can't
troubleshoot the unit yourself, I would advice you to look for a professional
to isolate the problem.
Also, check if your unit is still under warranty/extended warranty
period, avail it because the manufacturer will fix it for free. Opening the
back cover will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Hi rwnoyes,
Here are some basic steps that may help you fixing the problem. You should
prepare tools and multimeter.
I'm assuming that your unit is dead set without an standby LED
light.1.Power cord - check the cord it might be opened (no
continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse-
sometimes the fuse fail because of the power
surge, replacing with new one will cure the problem, If this is the case
I've advice you to use surge protector/AVR (Automatic Voltage Regulator).
However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the
linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and
still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch
anything because there somefatal components (Electrolytic capacitors) stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician
because isolating the problem on the power supply is technical and complicated.
Also check if your unit is under warranty before opening the back
panel, it will void the warranty. Avail it because the manufacturer of your
unit will fix it for free or a little charge only.
Hope it may help you.
Thanks for using fixya.
53 questions posted
210 Questions
52 Questions
25 Questions
31 Questions
27 Questions
