20 Most Recent
Ariston Technologies AW125NA 13 lbs. Load Capacity Washer Questions & Answers
Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
3/16/2020 7:30:19 AM •
Ariston...
Answered
on Mar 16, 2020
The ariston washing 125 show h2o on the scrim
The washing machine fails to load water (The wording H20 is displayed).
- The water inlet hose is not connected to the tap.
- The hose is bent.
- The water tap is not turned on.
- There is a water shortage.
- The water pressure is insufficient.
- The START/RESET button has not been pressed.
Dado
9/22/2018 3:52:01 AM •
Ariston...
Answered
on Sep 22, 2018
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
Dado
10/28/2015 7:46:15 PM •
Ariston...
Answered
on Oct 28, 2015
Error code 1
F01: Triac Short circuit
Overhaul CNE
Replace Card
Dado
10/6/2015 6:41:48 PM •
Ariston...
Answered
on Oct 06, 2015
Ariston washing 125 is flushing h2o on the screen
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
10/6/2015 6:29:34 PM •
Ariston...
Answered
on Oct 06, 2015
My ariston 125washing machine is flushing H2O on the scrim
displayed).
• The hose is bent.
Dado
10/6/2015 6:28:38 PM •
Ariston...
Answered
on Oct 06, 2015
Aml 125 washer - washing for hours
i would never suggest working or attempting to work on a machine covered by guarantee but this sounds like there is a fault with the heat cycle, obviously the machine keeps tumbling until the heat reaches the right temperature, with a heat fault it will not advance,
to test without removing screws etc, press any heat option button like economy or turn heat dial to no heat etc, see what happens next.
hope i have helped, if so rate me please,
please note most engineers know if a machine of that age has been worked on and this will void any guarantee
4/13/2014 7:35:49 AM •
Ariston...
Answered
on Apr 13, 2014
