20 Most Recent Hoover Nextra 160 HNWF 3137 Front Load Washer / Dryer Questions & Answers
Ahaaaa... BALANCE your loads... true for Life too!
Also know some springs "age" and don't provide the "RESISTANCE" needed to keep your drum in place... so they may LOOK PERFECTLY GOOD, but are actually tired from constant stress.
Do your best to use SPRINGS DESIGNED for your washer!
YOU failed to include your model number so I can't be more specific than this.
Anthony
Hoover Nextra... | Answered on Dec 24, 2017
hi my hoover front loader doesn,t fill. water in the machine I dont know what to do.any one help me thanks
Hoover Nextra... | Answered on Sep 09, 2014
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Hoover Nextra... | Answered on Nov 11, 2013
were is the filter located on hoover 1300 washer dryer
Hoover Nextra... | Answered on Jan 22, 2013
you probably need new carbon brushes on main wash motor . which off at wall and unplug . remove motor and check carbons .If you cannot do this your self call your local engineer .
Hoover Nextra... | Answered on Jul 30, 2012
REPLACE HEAT ELEMENT TO SOLVE DRYER PROBLEM
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Please score this solution accordingly and good luck!
John C
Hoover Nextra... | Answered on Apr 10, 2011
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
tukuymhg
Hoover Nextra... | Answered on Sep 29, 2010
Check the heating element Should read 28 ohms on a multimeter if shows open circuit. no reading then replace...
Hoover Nextra... | Answered on Jun 06, 2010
Either your heating element went out or your thermostat (which regulates the temp).
Hoover Nextra... | Answered on Jan 30, 2010
Hoover Nextra 160 HNWF 3137 Front Load Washer / Dryer Logo
Popular Tags
39 questions posted
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
machine drum not turn wash or spin
  • Washing Machines
