20 Most Recent
Sub-Zero 695/S Side by Side Refrigerator Questions & Answers
How do I get the grill cover off to clean the
There are 3 screws that go up into the grill from just inside the upper part of the fridge and freezer. Remove these and it will easily come off. Look for the two long springs as you remove it and disconnect these so it can be set aside.
Need owners manual for a Sub-Zero 695 and maintenance manual
If your trying to remove the grill plate thats located at the top of the machine what you need to do is open both the freezer and the refridgerator doors and look up. There are three vertical phillips head screws that you'll need to remove first. After that you'll be able to pull the grate forward and remove the springs, one on each side that keeps tension on the grate. Once those are removed, the grate will be easy to take off. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
I have locked out the ice maker, water dispenser
Check for a door switch on the cabinet side oft the freezer door. It usually is near the hinge fold area of the door. Depressing the plunger should make the freezer compartment light go on and off. The switch also controls the icemaker auger power by shutting it off when the door is open. If the door switch has failed you will not get ice or water from the door dispenser. There are 2 plastic lock tabs of the side of the door switch to remove it. Use a knife blade or putty knife to unlock the tabs on the switch.
Also try holding the lock button for some seconds if that helps.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Chemical smell in refrigerator
wipe it out with a clorine bleach solution,leave the door ajar to gas off and use a syringe to blow out the drain hole.wipe dry then cover any open topped food containers with cling film.as all fridge/freezers work best when 3/4 full.use empty airtight boxes to fill any spaces,she/he will notice a big difference in lower running costs...
whilst the freezer may be frost free, the fridge is not, so expect condensation to form on any gloss surfaces...(the more airspace the more condensation........)
Why is the panel between the freezer and
Hi, try vaccumming under your frig coils, and pull away from the wall and clean under there too. I would check to see if the fan behind the unit is spinning(its supposed to cool the compressor) if its not you will need to replace that. A pretty common problem easily fixed
My sub-zero 695 motor keeps running, very noisy..
If it is one with the compressor on top . Check the coils up top . You may find that they need cleaning because it sound like it's unable to cool enough to satisfy the thermostat therefore it runs all the time trying to.
Please rate solution
Ice and water won't come out dispenser
here is link to your owners manual
subzero.com
and here are instructions for using the lock feature..
LOCK
For Models 685 and 695, the lock feature is
used to prevent unintended ice and water
dispensing. When the dispenser is locked, all
key pads on the glasswell are deactivated to
allow cleaning or to prevent small children
from using the dispenser.
To activate the lock feature, hold down the
LIGHT key pad on the glasswell until the key
pad lights flash once and the red LOCK icon is
illuminated (approximately five seconds). The
lights will remain in the state they were in
before the lock feature was activated.
To deactivate the lock feature, hold down the
LIGHT key pad until the key pad lights flash
once and the red LOCK icon is no longer illuminated
before the lock feature was deactivated.
Thanks Peyton
Icemaker works but dispenser not
seems like everyone has the same problem, have to take a screw driver and be careful taking the front cover off, it is possible the micro switch could be bad or not making contact somehow. that is my guess. good luck. you can call v and v appliance parts ask for tom 330-743-7300 give model # and he can guide you over the phone and actually give you some good advice on working on it.
