20 Most Recent Nikon Coolpix 5900 Digital Camera Questions & Answers
Nikon coolpix 5200 won't except 4gb SDHC card
Correct. The 5200 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
4/22/2014 2:30:30 PM • Nikon Coolpix... • Answered on Apr 22, 2014
0answers
I encounter error message said
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/4/2011 9:57:44 PM • Nikon Coolpix... • Answered on Mar 04, 2011
I have a lens error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
1/26/2011 8:06:49 PM • Nikon Coolpix... • Answered on Jan 26, 2011
2answers
Why my 4GB SDcard can not work at my NIKON coolpix
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
1/16/2011 6:04:41 PM • Nikon Coolpix... • Answered on Jan 16, 2011
Memory card is write protected
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
11/26/2010 7:17:16 PM • Nikon Coolpix... • Answered on Nov 26, 2010
Battery door cover
http://uscamera.com/1C998-654.htm
6/14/2010 10:06:00 PM • Nikon Coolpix... • Answered on Jun 14, 2010
Camera dropped in water. removed battery and card
Its fried. Buy a new camera...or....If you take it apart again put parts in bags of dry white rice ..rice absorbs moisture..then put it all together and try it again...its a last ditch effort.
6/12/2010 9:20:03 PM • Nikon Coolpix... • Answered on Jun 12, 2010
2answers
Won't turn on.
This is caused by the camera not charging the flash capacitor inside thus it will not power the rest of the camera. You going to need to take it in to a local shop and have them look at it. This is something a end users cannot just open up and do.
Thanks and please do leave a postive rating and feedback Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5/18/2010 2:04:13 AM • Nikon Coolpix... • Answered on May 18, 2010
Replace display
Unfortunately it costs more than your camera is worth. You can buy another Coolpix 5900 in a used but fully functional condition for less than the new spare [part alone, so I suggest that is what you do.
2/25/2010 1:53:14 PM • Nikon Coolpix... • Answered on Feb 25, 2010
Help! I'm trying to transfer my pictures from my
Blame Microsoft updates. Use a card reader to download your pics to a folder you create on your desktop.
12/3/2009 9:31:29 PM • Nikon Coolpix... • Answered on Dec 03, 2009
I was looking threw my photos then it jus switched
Make sure the battery is good or charged to the full.
If it will not turn on, then it needs repair.
Another possibility would be to sell it on a site like Ebay for parts, as is, or repair parts.
10/7/2009 1:21:46 AM • Nikon Coolpix... • Answered on Oct 07, 2009
Memory card cannot read!!!
sometimes lapstops and PCS as well as Cameras can go out of line. That is the formatting in a particular PC may not be able to be read in another.
In you case this may not be so, as the card now cannot be seen. It would have been interesting to see if it could have read it before it was formatted by your laptop. Try another card in the camera first. If no other card can be read then the problem is on the read head of the camera.
This may be just dirt or damage, and it will have to be repaired. But try another card first as the card is cheaper than a repair.
Thanlks for using FIXYA
9/21/2009 12:48:04 AM • Nikon Coolpix... • Answered on Sep 21, 2009
2answers
Helpp! exceeded the power limits on its hub port?
a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
4/27/2009 8:03:13 PM • Nikon Coolpix... • Answered on Apr 27, 2009
2answers
Auto-focus isn't working
Try checking your settings for the type of shot you are taking and for the type of focus......
type of shot is the dial on the top, and then:
1) menu, metering
and also check your autofocus mode
2)menu, autofocus; try the single autofocus, it might be set to continual
Also, you could try updating the firmware in your camera. You do this through the Nikon website.
3/1/2009 4:57:24 AM • Nikon Coolpix... • Answered on Mar 01, 2009
How do you activate red eye reduction in the 5900?
To take photos with red eye reduction requires your flash to firerapidly before snapping the pic. Make sure camera is in record mode pres the 4 way switch with the lightning sign on it. The flash modes will pop up. select red eye flash.
To fix red-eye after a photo is taken. Bring up the photo in playback mode and press menu button. Red eye reduction should be available as one of the menu items. Otherwise, display the pic, press OK button in center and if you like the fixed picture then select yes to store it.
1/20/2009 12:22:40 PM • Nikon Coolpix... • Answered on Jan 20, 2009
Computer doesn't connect to camera
Might be as simple as a damaged lead.
Have you, or a friend got another device with the same type of lead?
Try it, see if it makes any difference. Also try a different USB socket in case that is the problem.
If all else fails, you could just get a memory card reader & work around it that way.
9/28/2008 7:59:36 PM • Nikon Coolpix... • Answered on Sep 28, 2008
Nikon Coolpix 5900 Digital Camera Logo
30 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
4gb sdcard not work nikon coolpix
  • Cameras
