20 Most Recent
Nokia C2-03 DUAL SIM DUALBAND PHONE NOT COMPATIBLE IN US/CA Questions & Answers
Forgot the password to unlock the phone
You can format your Nokia C2 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345. If it is not working try this code: You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
HOW I CAN RESTORE C2-03 MOBILE PHONE WHEN SWITCH OFF
You cannot restore when your mobile is switched off. Switch ur mobile C2-03 go to settings, then scroll down to the last option restore factory settings.....they will ask you whether you have to restore simply settings or all data? It is on ur wish...select option, then enter the security code 12345 then click restore...ok. You will get your mobile restored!!
Whatsapp
In Nokia C2-03 Whatsapp is not supported .!!So you can't download it & seen downloading fail .
Restriction code for Nokia 2690
It is normally recommended you Don't post your IMEI on websites. It is a security code for that phone.
Usually the IMEI number has to be reset by your network provider. It normally cannot be done directly from the handset. Did the handset accept the new sim card. Some handsets can be locked to a specific network and changing network can stop your phone from working.
Nokia 2730C-1. can I unlock the network
If the phone was not used 2012, the phone number and phone have been deactivated from the network you used to pay for service. You need to set up a new contract as they expire after about 2 years of inactivity.
