20 Most Recent
Denon AVR-1082 Receiver Questions & Answers
Music still comes out of my speakers when I have
Some receivers have a speakers on off button. But if the Denon doesn't and inserting a headphones used to switch the speakers off. The don't worry it's nothing serious. All that likely to have happened is that inside the headphone socket some "pins" have bent out of shape and are not contacting. Depending on the type of socket, these can be bent back into place sometimes. But even if the headphone socket needs replacing they are not expensive and if you are any good with a soldering iron you could do the job yourself.
Can not get the optical connection to work from my
there are three points for the same RED,GREEN,BLUE please use the same combination in your television also if you dont have these three colours points on the back panel on your television so try to plugg in the YELLOW point on the television point
No speaker output from television
Check to make sure you have the TV input connections in the correct
slots. Sometimes there are two possible inputs for a TV. One being a monitor 1 and the other a monitor 2. There could also be speaker select buttons on the receiver that correspond to each.
Also check the TV audio settings to make sure the output connections are sending an audio signal, also known as external speakers.
I have a Denon AVR-1500 Reciever and I would like
How are you trying to connect your ipod to the Denon? i.e. What connector, or cables are you trying to use?
If nothing else work, you could try and use the headphone output of the ipod to connect to your receiver. ( Cable required would be stere pin to RCA stereo out). The volume control of the ipod will then become the gain control.
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
