20 Most Recent
T-View TView (DVD170TV) Motorized 7" In-Dash Widescreen TFT/LCD Monitor with DVD Player, AM/FM/TV Tuner and... Car Video Player Questions & Answers
How do i bypass the
This can be done, although may not be legal in some states. Look around on google. Just know that there is a reson the park kill feature is there in the first place.
How do i take the dvd safety feature off so i can
There is a wire that you are supposed to hook up to your emergency brake or another source to let it know your are parked. That same wire usually relies on a ground. I just grounded mine to a good ground under the dash and it worked great. Hope this helps and good luck!
Does It Fit?
Welcome to Fixya! It will fit But, You may need an Install kit for it. Go to Crutchfield.com and look at them. Just enter the Info. for your Car and it will give you everything that will fit and what you would need.
WIREING
Not familiar with that brand, but it should use the international standard colors:
yellow- battery
red- ignition
black-ground
white- left front +
white/blk- left front -
gray- rt front +
gray/blk- rt front-
purple- rt rear +
purple/blk- rt rear-
green- left rear+
grn/blk- left rear -
Tview model DVD799ts-bl
hi, if this is still covered with warranty try to ask a replacement/repair. it has to be an internal problem
Tview d72tsb screen not on
I'm having the same issue. the bottom buttons illuminate and can hear the cd.. just no sound through the speakers and screen stays blank..
