20 Most Recent
Pds GE Profile Bottom-Freezer Drawer Refrigerator Energy Star 22.2 Cu. Ft. - PDS22MFS Questions & Answers
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Icemaker in brand new fridge makes ice that tastes like mildew
brand new?OK...first,did you flush the water filter by dispencing 2 pitchers of water through the door.wait,that it.basicly the water in your ice maker is the same water that comes out of your tap.you may find that you dont like the filtered water, there should be a bypass plug that can go in place of the filter.solution wise thats about it.
Water taste and smells like mildew
Hi and welcome to FixYa. I am Kelly.
How about the house tap water same odor and taste or just the fridge?
If it is just the Fridge I am assuming your unit has been around for a while.
If you have a mildew build up in the plastic tubing of your ref it can be a tedious cleaning procedure to get it all out of the system The stuff ends up sticking to all of the plastic tubing inside the unit and is so hard to get rid of. What you can do is have all of the plastic lines changed out in the Refridgerator from the water valve outlet to the the water in door and icemaker. It is just time consuming to do it.
Water supply to unit off for the steps below.
You can try using a small baster (I use a hair dye applicator bottle) and a bleached water mix that is not too strong. I would recommend that you start AFTER the water valve in the bottom of the unit. You have got to be able to introdue enough pressure through the system so that when the water in door switch is activate that the bleached mixture will flow out of the spout. You will have to introduce the water until you can smell it in the water you get from the glass you used to catch the water. Then let it stand for an hour. Re-intorduce the same amount of bleached water as before and wait another hour. After the second mixed water bleaching reconnect the water supply and purge it at the water in door outlet with a glass.
Probably sounds a bit much but this is from experience and believe me it does take lots of time.
I am sure this is not what you were expecting but it really is the only way your going to rid yourself of the bad smelling and tasting water CURSE.
Thanks for using FixYa!
Kelly
Freezer drawer jars open at upper right corner
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Where is the defrost timer located in hisense upside down fridge freezer on model NO# HR6BMFF520S
The defrost timer in a Hisense upside-down fridge freezer, model number HR6BMFF520S, is typically located within the control panel or the refrigerator compartment. Here are the general steps to locate it:
- Check the Control Panel: Start by inspecting the control panel of the refrigerator. Look for any knobs, buttons, or switches that control the defrost cycle. The defrost timer may be integrated into this panel.
- Inside the Refrigerator Compartment: If you don't find the defrost timer in the control panel, check inside the refrigerator compartment. It might be located near the temperature control settings or the light fixture. You may need to remove any covers or panels to access it.
- Consult the User Manual: If you're having trouble locating the defrost timer, refer to the user manual that came with your fridge freezer. It often contains detailed diagrams and information about the location of various components, including the defrost timer.
- Contact Hisense Customer Support: If you're still unable to locate the defrost timer, consider reaching out to Hisense customer support for assistance. They can provide specific guidance based on your refrigerator model and help you locate the timer.
Once you've located the defrost timer, you can follow the manufacturer's instructions for troubleshooting or replacing it if necessary.
How do I replace the boards in n'finity pro hdx 77-bottle wine refrigerator. Model BU-270D-A1
Remove all bottles and shelves from the unit.
Unplug the power cord from the outlet and wait for the unit to cool down completely.
Locate the screws that secure the boards to the back wall of the unit and remove them with a screwdriver.
Carefully pull out the boards and disconnect any wires or connectors attached to them.
Replace the boards with new ones and reconnect any wires or connectors.
Secure the boards to the back wall with the screws and tighten them firmly.
Plug the power cord back into the outlet and turn on the unit.
Reinstall the shelves and bottles and adjust the temperature settings as desired.
