20 Most Recent
Denon DRR-M30 Dual Cassette Deck Questions & Answers
Hi. I have a much-loved
Hi. I had a similar problem. Remove the casing and you will see a rubber belt on the left hand side which looks like a miniature car fan belt. Even if it looks ok, the likelihood is that it is now slack and not operating properly. Its purpose appears to be to drive a white plastic cog wheel which secures the tray in position ready for the cassette to play. If the tension is insufficient to lock the tray, it automatically ejects after a couple of seconds of the whirring sound you describe. Contact Charles Hyde & Son Ltd of York who are main distributors for Denon and order part number 7790031, called a tray loading belt. The Sales number is 01759 303068 and that takes you right through to someone who will process your order; the part costs about £10 incl postage. They sent the part the day after I phoned - great service. It takes a few seconds to remove the old belt and replace it with the new one. Good luck
Hi ive got a denon drr-m30 it keeps on poping the back out
The solution from AlecBrown133 nails it. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr m30 and it is significantly cheaper than the 10 pound option.
Tape stuck
HELLO
Go to Audiokarma.org on the web. The guys on there are brilliant and I'm sure someone may have the answer. You will have to register to post your problems - it's worth a shot!
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
What's wrong with my denon avr1601
The best thing would be to check all the connections, and if everything is in order and tight and still not working properly, then you'll need to notify Denon customer support for further assistance
Denon dvd 1940 problem. All funcion is ok, but audio impul not works? but
Check all connections from the DVD player to your amplifier/receiver and TV. Make sure the audio cables are securely connected at both ends.
Try connecting the DVD player to another amplifier/audio system using different cables to isolate if the issue is with the player or cables.
Check the audio settings on the DVD player - make sure audio output is enabled and set to an appropriate format like PCM or Bitstream. Go through the audio setup menu and reset to factory defaults.
Make sure the volume on the DVD player is turned up and not muted/very low. Try different audio tracks on a DVD movie to test.
If connected digitally via HDMI, try swapping to analog RCA connections instead. Or vice versa.
Try playing audio CDs to see if the issue only affects DVD movies or all audio.
Make sure the audio on the disks themselves are okay by testing in another player.
If there was a power surge or electrical issue, the audio circuits could have been damaged. A repair service may be needed.
As a last resort, perform a factory reset or firmware update on the DVD player.
