20 Most Recent
Proview PL926WBi 19" LCD Monitor Questions & Answers
Monitor is blank
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
ENERGY SAver is stuck on
I know it's an older post, but you still may be waiting an answer:
What is probably happening is Your power board is failing to maintain power enough to run the bulbs and the rest.
That is why it takes long to start up and why it goes into sleep mode.
Does the power button stay lit (getting signal) or turn to amber (sleep mode) or does it flash.
powerseller
bammbammfran
The color is not right on monitor missing red
Try disconnecting the monitor from your computer and checking the pins in the connector to see if any of them are bent or flat. If they are, try to straighten them if possible and that may resolve your problem. Otherwise try resetting your monitor, if it has it as an option in it's configuration menu to do so.
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
I have a 19 Proview
Public sales or auctions from corporations or schools are the best places to get computer cables for very very cheap.
If you are looking to purchase new cables places like
http://www.pricewatch.com list competitive prices for the cables you are needing.
Blank screen with message "mode not supported"
Hi
How have you connected the monitor to the computer?
Is it through the vga or the dvi port?
Pls press the monitor menu button and change the mode to vga or dvi depending on the connection that you have now.
You might also get a vga to dvi adapter and connect the monitor to the computer.
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
How to remove outer case on Pl926wbi
Remove the four bezel screws on the bottom edge of the monitor. Gently pry up where you removed the screws and slide the bezel off towards the top of the monitor. The six mounting screws for the lcd panel will be visible. Remove them and inplug the lcd cables and set it aside. You now have access to the main circuits.
Deguss
You can not degauss a LCD monitor.
Degaussing is to reallign the magnetic field on a CRT. An
lcd has no such field.
http://club.cdfreaks.com/f7/lcd-19-inches-monitor-always-blurred-95364/
The last time I heard of someone wanting a Degauss for an LCD, it was because there kid took a magnet to there LCD monitor. This will destroy the TFT pixels.
http://en.wikipedia.org/wiki/TFT_LCD
Proview 926 wbi monitor
have a look at the board open up the monitor and remove the boards and you have to look for doomed or colored caps, they will be obvious compared to the good flat caps on the board. replacing these will most likely repair your issues.
