20 Most Recent Equator EZ 2512 CEE Front Load Washer / Dryer Questions & Answers
My equator EZ 2512 CEE washer/dryer suddenly wont
If you are still looking for a solution to this here it is:
In these machines if you try to change the setting of the washer knob without letting a cycle finish which is already set it may happen that the unit won't function properly and hence the unit needs to be reseted. There is a reset procedure for the same and let me know if you would like have the same.
If the door is not opening it is advisable to reset the unit first and then try opening the door which should work and also the door handle won't break then.
If you have already replaced the door handle on your machine it is fine or else you may want to order the same from appliancedesk.com
2/26/2010 10:44:52 AM • Equator EZ 2512... • Answered on Feb 26, 2010
Broken Handel for a Equator ez 2512 CE
If you are still waiting for this part you can get it from appliance desk through their website www.appliancedesk.com click on shop parts.
2/25/2010 7:13:39 PM • Equator EZ 2512... • Answered on Feb 25, 2010
Equator ez2512 washer dryer keeps throwing the main belt off.
somthing is going to be obvious there.you have to inspect it whatch it while it runs
12/31/2008 8:22:52 PM • Equator EZ 2512... • Answered on Dec 31, 2008
Equator door handle
Here is the phone number for equator, 1800-935-1955 or parts and service 800-776-3538. They sould be able to help you.
Their address is 10067 Timber Oak Dr. Houston, TX 77080-7045
12/31/2008 8:09:52 PM • Equator EZ 2512... • Answered on Dec 31, 2008
2answers
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
2/22/2008 4:32:38 AM • Equator EZ 2512... • Answered on Feb 22, 2008
Pre-set buttons
they are activated when pressed in
2/20/2008 3:19:50 AM • Equator EZ 2512... • Answered on Feb 20, 2008
2answers
Fan belt broken?
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
10/29/2007 5:20:01 PM • Equator EZ 2512... • Answered on Oct 29, 2007
Dryer not drying properly
Check you drain hose is if it is kinked or obstructed an anyway, there is a filter element on the end of the pump it may be cloggedthe pump is self cleaning. the pump is located on the bottom. the condenser is on top center and the blower motor is in the center. also check the impeller at the end of the condenser motor..let me know if this helps
8/26/2007 5:48:04 AM • Equator EZ 2512... • Answered on Aug 26, 2007
Equator Advanced Appliances EW 835 18-lb Washing Machine. How do you shut off memory on an EW835
Yes just disconnect it from the mains supply and leave it overnight. It will lose its stored memory. Or from Model EW-824 Manual Press this button to select once of the four positions, then select the additional options for your favorite washing cycles, then press Start/Pause button to run this program, and this program will be memorized. If you want to run the memorized program later, press this button to select one of them, then press Start/Pause button. Turn the dial to align "OFF" to cancel the memory operation https://www.google.com/search?q=Equator+835+clear+memory Manual for model 835 at memory page https://www.manualslib.com/manual/2389625/Equator-Super-Washer.html?page=17&term=memory&selected=1#manual Press this button to select one of the four memory settings. Then select the your favorite Memory button wash cycles. Then press START/PAUSE button to run this program, and this program will be memorized. If you want to run the memorized program later, press this button to select desired program and then press START/PAUSE button ..
2/14/2024 7:57:26 PM • Equator Washing... • Answered on Feb 14, 2024
On the EQUATOR 4400N how do you replace the main motor
Do not pull the connector appart by the wires! screenshot 2024-02-04 at 12.29.19-undefined-undefined-0.png
2/4/2024 12:30:26 PM • Equator Washing... • Answered on Feb 04, 2024
How do I reset my Equator Super Combo washer Dryer EZ4000?
To reset your Equator Super Combo washer dryer EZ4000, you can try the following steps: 1. Unplug the unit from the power source and wait for a few minutes. 2. Plug the unit back in. 3. Press and hold the "Start/Pause" button for about 5 seconds to reset the machine. This should reset the washer dryer and clear any error codes that may be causing the issue. Regarding the door interlock switch, you can try finding a replacement locally by contacting appliance repair shops or stores that specialize in appliance parts. You can also search online for retailers or websites that sell spare parts for Equator appliances. Provide them with the make and model of your washer dryer to ensure you get the correct part. If the above steps do not resolve the issue with your washer dryer, it may be best to contact Equator Appliances directly or consult a professional appliance repair technician for further assistance. They will be able to provide you with more specific guidance and help you troubleshoot the problem effectively.
5/25/2023 5:29:27 AM • Equator Washing... • Answered on May 25, 2023
Equator Super Combo Washer/Dryer Unit Model 4400. Does anyone know how to repair/replace the display and/or heating element please?
This is a brand I have never heard of and it appears to be sold under different names. Likely made in China or somewhere similar. The best way to contact companies is by phone. Element, no details on how. It would be a matter of taking it apart and finding it. https://www.google.com/search?q=Equator+Super+Combo+4400+replace+heating+element Display not much help either https://www.google.com/search?q=equator+super+combo+4400+replace+heating+display+unit Look at the ONE star reviews!! https://www.walmart.ca/en/ip/Equator-Super-Combo-EZ-4400-CV-Washer-dryer-width-23-5-in-depth-22-in-height-33-5-in-front-loading-13-lbs-1200-rpm-white/PRD43BPX7L923KW Here is the phone number though :>D Equator Appliances Team Hi Dorrie, I am so sorry to hear that you are having issues with the motor on your combo washer dryer. What you described is not normal at all and we want to make this issue right for you asap. Please call us directly at 800-490-8018 so we can help you with the issue you are facing. Thanks ..
7/31/2022 8:56:16 PM • Equator Washing... • Answered on Jul 31, 2022
Equator Super Combo washer dryer Display won't turn on but works fine. Why is it doing this?
It would be best to include a model number as there are various models of this. That aside, it is possible that the communication cable between the display panel and the electronics has dislodged. That is item 7 in the attached manual: file:///C:/Users/Donald/AppData/Local/Temp/4000.pdf
11/3/2021 4:11:50 PM • Equator Washing... • Answered on Nov 03, 2021
Equator EZ3600 cee- door will not unlock after spin cycle ends, waited 2 to 3 minutes
If you can see water in the tub, the machine is not draining the water out, and preventing the door from opening, It could also be a faulty door interlock switch. I hope this helps?
9/10/2019 6:50:47 PM • Equator Washing... • Answered on Sep 10, 2019
Equator EZ 2512 CEE Front Load Washer / Dryer Logo
18 questions posted
Top Equator Washing Machines Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Equator Washing Machines
Most Popular Question
fan belt broken
  • Washing Machines
