20 Most Recent
Dk Multimedia I Love Spelling (798936829047) for PC, Mac Questions & Answers
How do I set it up.
if it does not run automatically, try going to my computer. Drive D; open this drive with a right click on its icon and then look for aile called setup.exe click on that file and follow the instructions. Yuo might also try looking for autorun.exe in the same place.
I keep getting the message The sound software is
I downloaded a fix patch from the software companies web site.
http://support.selectsoft.com/
I had a hard time getting that to load, so I typed in www.selectsoft.com then I clicked on the tab marked support then clicked on the problem on the right had side. It gave me two fixes, the first one did not work for my computer, so I used the second and it worked great. I found this on one of the fixya bulletins.
NO SOUND ON OLD WIN95 TITLE-DK Multimedia
Try These Sir:-----------
- Right Click the encyclopedia.
- Select Properties.
- Go to tab Compatibility.
- Go to Run The program in compatiblity mode for.
- There select Windows 95.
This will solve it. Than you Sir to contact Fixya.
Sound software
hello sir,
1.Go to the Control Panel
2. Click sound and audio properties
3. Then click the option hardware
4. U now see the list of audio properties software name
5. Click the software properties to check whether at Device Usage => Use this device (Enable)
6. Check all the other option can enabled it or not
7. If it not working or cleared, try to reinstall audio driver software.
Best of Luck
Cheers!!!!!
I just purchased DK's CD-ROM's
try right clicking on the file and then clicking properties and choose compatibility and choose windows xp sp3 click apply then ok and try running it again, see if that cures the problem
if this was helpful please vote for me
I am trying to install
http://support.selectsoft.com/download/SP1fix.exe
I hope this comes across as a link, this is a fix for this problem. If not just copy and paste the following in your address bar with http:// in front of it. Hope this helps.
If this helps you resolve your problem, please
indicate by giving 4 thumbs up or saying
"Thanks" Thank you for using FixYa!
I am trying to run
XP should be able to run it because they're backwards compatible with all Windows 98 software. Check your sound card in the Device Manager and verify the device and its' driver are installed. If not, re-install the driver for your sound card.
I have Vista OS. I
hi,
The Software is not installed completely, so kindly uninstall the application by navigating from control panel-> Add or remove programs and reboot the machine.
once the machine turn up, then install the application as fresh copy. it should fix the issue.
Thanks,
Bharathidasann
