20 Most Recent
Mitsubishi WD62527 62 in. LCD HDTV Questions & Answers
Wont come on
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
For more information, check the link http://electronicshelponline.blogspot.com/
How to fix the ballast on my tv
Presuming the ballast is bad it is only available as a complete unit---Google the model number with "ballast" to locate a part number and or the part.
62 in LCD mitsubishi
Not too sure about the thumping, possibly the cabinet expanding and/or contracting with heat, the lack of and weather change. But the scratching sound could very well be the HV discharge. So, not being able to hear it myself, I would suspect that yes it's probably normal.
Bill
My Mitsubishi wd-63527 turns on for a few seconds and shuts itself off.
The set may have (some models) a recessed reset button on front but that rarely does any good.This model should have two resets other than that one----soft reset if it has it is with Mitsubishi remote: On, Menu,1,2,3 enter.Set also has a hard reset which requires a four digit number code and resets set back to factory---it is a last resort and should not be done unless the soft one does not help.I would have the remote tested as without it you cannot do any reset--Most digital cameras in a dimly lighted or dark room will react on screen display when a remote is pointed at them and buttons pushed or most shops have a tester which will show and react to each and every button when remote is pointed at them and buttons pressed.This model could have a keyboard lock feature which disables the keyboard but remote should still function.First thing is to know if remote actually is working or not.
Replaced lamp, tv worked great
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
I have a mitsubishi 54in
Please tell me what exactly do you meanby opticel. Is it the optical block or is something else?
I have a Mitsubishi WD-62530.
If you have sound and no picture on a DLP it usually means that there is a problem with the Lamp. When you say amber light, does this mean that its the amber lamp light?
