20 Most Recent
LG Unlocked A100 CePhone Questions & Answers
Why can't I send or receive text messages on my LG A100?
for sending text messages :1.go to your message settings and check the message center number to see if it is correct2. call to your network operator customer care3. request the message center number...4.note it down5. go to message settings>message center number6. insert the number which is noted by you and save itthis solves your messaging problem ...Good luck
I need the unlock my mobile
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
