20 Most Recent
Nikon Coolpix 5200 Digital Camera Questions & Answers
How do you change a nikon camerer coolpix 5200 from belgium to english
I am NOT an expert on this problem as I have never changed languages. Language is typically in the TOOLS menu (Wrench) It you get to settings and English is greyed out then I am stuck. If you have many settings you want to keep please ignore what I say here. One workaround that MAY work is reset to factory settings. It could be one of your settings that keeps language setting greyed out. A reset makes the camera like you just purchased it new.
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Not clicking
Put battery s in camera put sd card in slot problem solved
How to fit a filter to a 18-55mm lens
Remove the lens cap and lens hood, if present. On the front of the lens is a threaded mount, like the mouth of a jar. Just screw the filter on, like screwing a lid onto a jar.
Battery door repair
When you want your camera repaired, option one is contact the Nikon service centre closest to you.
Option two, if you want to do it yourself, goto ifixit.com. There you find lots of videos books and pictures about electronic repair. Perhaps your camera is there too, or one that looks the same. On that site you also can order spare parts and tools if you need so.
Won't turn on
It's brand new - take it right back and get it exchanged for a working unit!!!!!!!!!!!!!!
How do I use my 5200 nikon as a webcam?
The 5200 was designed primarily as a still camera, storing images (and videos) to memory. It was not designed to function as a webcam, streaming live videos to another device.
That probably wasn't the answer you wanted to see, but there it is.
Can self timer delay be extended
Sorry, the 5200 is limited to a three-second or ten-second delay with the self-timer, and there is no provision for remotely triggering the camera.
Pause recording
No. You have to do it the same way they do in Hollywood: take two clips and splice them together in the editing stage.
