20 Most Recent
Matrix Star SP212FD Receipt Printer Questions & Answers
Wep HQ1070 DX dot matrix printer,
printing wrong characters and other miscellaneous characters
I used to have a dot matrix printer which was a serial printer - it didn't work properly through the parallel printer port and had to be connected to the computer serial port.
Just to complicate matters further it had to be set up as an entirely different model but once done it worked very well.
The printer wasn't intended for domestic use but was widely used by large offices.
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
How to give test print through command prompt in windows-10.
you can print a test page from the command prompt using this command:
rundll32 printui.dll,PrintUIEntry /k /n “\\atl-ps-01\color-printer”
If you wanted to, you could wrap this command up in a VBScript and execute the test page from there. For more information about running command line tools from within a script take a gander at this classic Tales from the Script column (it’s actually the first Tales ever written
