20 Most Recent
Motorola Mobility Universal Bluetooth Wireless Headset H500 Headset Questions & Answers
How to turn on Motorola H700C wireless bluetooth
If you haven't figured it out by now, you have to push and hold the button down until it starts flashing.
Just a simple push of the button will not work.
If it's not connecting to the phone then you haven't paired it to the phone.
Pairing must be done for it to work.
The instructions should be with the headset.
1/21/2011 7:01:37 PM •
Motorola...
Answered
on Jan 21, 2011
I have charged the blue
Well, try to press the Call button: it is the button that has got telephone drawed. Hold it until you see the blue light steadily lit. That means that you just turned on and putted the headset into pairing mode. Now find Motorola H500 over your mobile phone. You will need to put a pass, and it is by default (i think, on ALL Motorola Headsets): 0000. You're ready for using!
12/19/2010 8:47:31 AM •
Motorola...
Answered
on Dec 19, 2010
Icom IC706mk2g Transceiver does not transmit in SSB (Single Side Band) (USB & LSB)
First, make sure that the microphone is properly connected to the transceiver. Check all the connections and ensure that there are no loose cables.
Next, check the settings on the transceiver to make sure that it is set to SSB mode. Sometimes, the mode settings can get changed accidentally, so it's important to double-check.
If the issue still persists, try resetting the transceiver to its factory settings. This can sometimes resolve any software glitches that may be causing the problem.
If none of these steps work, it's possible that there may be a hardware issue with the transceiver. In that case, it's best to contact a professional technician for further assistance.
3/28/2024 10:24:30 AM •
Radio...
Answered
6 hours ago
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
