20 Most Recent
Motorola Mobility Universal Bluetooth Headset H500 - Pink Headset Questions & Answers
HOW TO CHANGE BATTERY HEADSET H500
Why do you think you need to replace the battery? A common sign that your Motorola Bluetooth headset needs a new battery is when you repeatedly hear five quick high tones in successive, one-minute intervals. Another symptom of a low or dead battery is when you try to scroll to Power and your headset doesn't come on. The Motorola H500 headset has a long battery life, but the battery eventually will go bad. Unfortunately, the battery is integrated as part of the headset's circuitry and should not be replaced by its user. Motorola strongly advises against trying to change the battery. Attempting to replace the battery voids the headset's warranty. By sending the headset to Motorola for repair, you can have a new battery installed without the risk of damage to your equipment.
But you can try the following at your own risk:Locate the battery door at the rear of the headset and open it.Remove the old battery. Install a new battery to match the plus and minus illustrations on the battery compartment. Shut the battery door back in place.Select "Menu" on your phone. Select "Settings."Select "Connection," "Bluetooth Link," and "Setup."Select "Power." Select "Change."Select "On," and then press "Select."Press the "Call" button and hold it down. Release it when the LED light blinks.
10/13/2014 2:21:32 PM •
Motorola...
Answered
on Oct 13, 2014
Need the password for h500 bluetooth
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
5/1/2011 6:15:32 AM •
Motorola...
Answered
on May 01, 2011
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
on Apr 19, 2024
