20 Most Recent
Denon AVR-2106 Receiver Questions & Answers
Hello, I've got a Denon AVR-2106 dropping into
check the power supply for the micro controller \ logic.
5 or 3.3 Volt IC's
And check with AC measurement too ( try to measure AC ripple )
Could very well be dry electrolytic capacitors with excessive ESR.
Ed
I have audio but no video
This depends on the signal source. If it is digital, from a digital receiver, the audio will be either S/PDIF or Optical and the video will be a yellow RCA connector (co-axial). If analogue, the audio will be two RCA connectors (red-right and white-left) and the video will be component (green, blue, red RCA) Alternatively you may have a composite audio/video signal (yellow) which is both audio and video. Of course you must be sure to choose the inputs into which you have plugged your signal source. Cheers, Don.
Zone 2 does not respond
Make sure that you go into the speaker system menu and set it to zone 2. The zone 2 speaker jacks can be assigned to other things such as surround back.
