20 Most Recent
Candy CNW136 Front Load Washer/Dryer Questions & Answers
I have a candy CN105
Sounds like you need a new timer board/control package.
Most parts for modern washers cost almost as much as the thing is worth.
Then after you invest a lot of time and money you still have an older junk washer. Unless it's a simple filter or rubber gasket, I buy a new machine.
In the long run you will be ahead.
Instruction manual
Not drained in time allowed - washing machine fails to drain water
·Check that filter is not blocked or obstructed
·Check drain hose is clear of any blockage or obstruction
·Check wiring to drain pump
·Check drain pump is not defective
·Check level sensor or switch
Check wiring to level sensor
Mold in dryer
Mold grows in dark damp areas with reduced ventilation. Mold does not grow if humidity is below 60%.. If the area is air conditioned or dehumidified simply leave the door open. You could also park a "damp-rid" in the dryer when not in use. Don't forget to take it out before loading.
Machine stopped working during use.
Hello! There is a trouble shooting guide for major appliances that frequently suggest parts and video links on youtube that diagnose your problem & instruct you how to repair your appliance. The site is called Repairclinic.com. Make sure you have the model number before you begin since the instructions are model specific. Good luck.
Drum wont rotate at all
You mean it won't turn as in it is stuck? Or is it that the motor won't come on to turn it? Check door switch. Does dryer have power to it at all? Please rate my answer so I get points for it.
Whirlpool door lock
hi
We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
