20 Most Recent
Candy 24 in. CD950 Free-standing Dishwasher Questions & Answers
Dishwasher trips out
by trips out do you mean shuts off completly?or do you mean it trips off the breaker? check the electical connections on the bottom right corner if this is connected properly then you have a control board or wiring problem and it might be better to call a technician
Candy CD 950
We have sorted it out, we have managed to change the heating element for a new one, I actually asked a Candy Engineer who told us what to do, thanks.
Tripping out
Oh oh. Most probably you have an ( electrical ) earth-leak in your dishwasher.(DW)
In many cases this happens when the liquid in your DW must be heated. This heating is done by a resistor which you can see in the bottom of your DW ( a tube ).When heating up some liquid will get thru minor metal cracks in the outer resistance tube causing a path able to conduct some "leak"-current to the earth, and cause the the "differential" circuit breaker to switch off all current supply in house. ( Thanks it exist and works, it saved many lives)
Best is to ask a repair-service to do the job; this can be done at your home.At the same time they have to check the thermal protection in the DW.
If the resistor is not the failure, the electrical leak can come from other locations in the DW ; an isolation failure within the cabling or around the pump. It is not always evident to trace such an electrical leak, a repair service normally use a Megger ( this is real British ) to trace.
Hopefully you don't have to manual dishwash too long.
Candy
is the tablet released from the dispenser? if not the solenoid in the unit has gone and the dispenser unit will need replacing.
Candy
"e" is economy wash and the other buttons are temp selection.
i suspect that the problem may be the spray arms not rotating. open bthe door when on wash and check the arms are rotating. if not, remove the arms and clean - they tend to get blocked over a period of time.
the arms only rotate with water coming out of angled jets at the end
Ef error code on candy dishwasher
Kindly take care to peruse the data completely for all intents and purposes there to assist you with understanding shortcoming codes and to guard you. There are likewise a few assistance, tips and clues with a great deal of the issue codes distributed here that you for the most part won't find elsewhere and, as we learn, we add more data so in the event that you can't find what you want if it's not too much trouble, ask in the discussions.
Prior to utilizing this segment if it's not too much trouble, comprehend that shortcoming or blunder codes are utilized as a demonstrative guide, they are not a trade for symptomatic expertise with respect to the individual fixing the item and are not at all generally going to highlight the exact part that is flawed. All they do is provide you with a thought of where to begin searching for the shortcoming.
10/14/2023 9:49:12 PM •
Candy...
Answered
on Oct 14, 2023
Candy Dishwasher. It starts draining then before starting to start washing it shows E18.
Question edited for clarity.
Question moved to Candy DISHWASHER from washing machines.
E:18 or E18: Water Level error.
Wrong water level detected during loading.
Causes:
- Defective water inlet valve.
- Clogged air trap chamber.
- Damaged pressure switch hose.
- Faulty pressure level switch.
Solutions:
Unplug the dishwasher and:
- Check the Solenoid valve.
- Clean the air trap chamber.
- Find the air leakage in the pressure switch hose.
- Replace the pressure level switch.
3/19/2023 12:29:54 AM •
Candy...
Answered
on Mar 19, 2023
The washing machine Candy Alise 1400 rpm Washing / dryer
If the stop light on your Candy Alise 1400 RPM Washing Dryer is flashing all the time and will not start any program, you may need to reset the machine. To reset the machine, unplug the power cord from the wall outlet and wait for at least 30 seconds. Then plug the power cord back in and press the start button. This should reset the machine and allow you to start a program.
1/29/2023 10:44:06 AM •
Candy...
Answered
on Jan 29, 2023
