20 Most Recent Ricoh Aficio 3045, 3035 Kit Questions & Answers
the problem is with a electronic board, so nothing can be done by the used, the specific board need to be replaced.
Ricoh Aficio... | Answered on Mar 11, 2019
check the registration knob which you can turn by opening the front door and it is located on the right bottom. and also open the right cover to see do the paper comes out as you turn the know from the front, towards left...
Ricoh Aficio... | Answered on Oct 12, 2016
450
D
Feed Development Motor Error
•???? Motor lock caused by overload.
•???? Motor driver defective.
The PLL lock signal remains LOW for 2 s while the feed development motor is operating.
Ricoh Aficio... | Answered on Feb 17, 2015
ID sensor is defective. Try cleaning the sensors. If no luck, replace it.
Ricoh Aficio... | Answered on Feb 16, 2015
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Ricoh Aficio... | Answered on Oct 15, 2014
call tech or buy a drum assy
could be drum or fuser assy
will need to purchase a disk drive that works in this copier. pull old one out and buy one just like it.
Ricoh Aficio... | Answered on Aug 29, 2014
could be devlp powder is bad. replace and initialize devlp powder. could also do output check and turn toner motor on to make sure it works.
Ricoh Aficio... | Answered on Aug 27, 2014
When the machine is printing a
document stored using the copier
function, wait until printing has
finished before you store a document
in the Document Server.
A Press the {Document Server} key.
B Press [Scan Original].
C Enter a file name, user name, or
password if necessary.
Note
- If you do not enter a file name,
one is automatically assigned.
Reference
p.41 "To register or change the
user name"
p.41 "To change the file name"
p.42 "To set or change the password"
D Place originals either on the exposure
glass or in the ADF.
Reference
For information about types of
originals and how to place
them, see Copy Reference.
E Make any required settings.
Reference
For details, see Copy Reference.
F Press the {Start} key.
The document is stored in the Document
Server.
Note
- To stop scanning, press the
{Clear/Stop} key. To restart a
paused scanning job, press [Continue]
in the confirmation display.
To delete saved images
and cancel the job, press [Stop].
-When a password is set, appears
on the left side of the file
name.
- After scanning, stored documents
appear on the Select Files
to Print display. If this display
does not appear, press [Scanning
Finished].
- When placing an original on the
exposure glass, press [Scanning
Finished] after all the originals
have been scanned
To register or change the user name
A Press [Scan Original].
The Scan Original display appears.
B Press [User Name].
If user names are already registered,
the Change User Name display
appears. To use an
unregistered user name, press
[Non-programmed Name].
When no user name are registered
in the Address Book, the User
(Destination) Name entry display
appears.
When using a registered user
name in the Address Book
ASelect a registered user name
from the list, and then press
[OK].
To change your user name to an
unregistered user name, proceed
to the next step.
Reference
p.76 "Registering a New
User Code"
When using an unregistered user
ATo enter an unregistered user
name, press [Non-programmed
Name].
BEnter a new user name, and
then press [OK].
Reference
p.161 "Entering Text"
When no user name has been
registered in the Address Book
AEnter a new user name, and
then press [OK].
Reference
B Press [File Name].
The Change File Name display appears.
C Press [Delete All] to delete the old
file name.
Note
- You can also use [Backspace] to
delete unnecessary characters.
D Enter a new file name, and then
press [OK].
Note
- Up to 20 characters can be entered
as a file name. Note that
only 15 characters of each file
name appear in the document
list.
Reference
B Press [Password].
C Enter a password using the
number keys (four-to eight-digits),
and then press the {#} key.
D Reenter the password (four-to
eight-digits) for verification, and
E Press [OK].
Ricoh Aficio... | Answered on Jun 23, 2014
The Ricoh site says 'When printing a file containing a large number of bitmap images or fonts, some of the images or font may be lost.'
You do not say if the printer is on a server or network?
Ricoh Aficio... | Answered on Jun 21, 2014
Either the feed motor in the back of the tube or inside the chuck where the opening of the tube sits, if you take the chuck appart there is plastic feed fins and they break off and don't feed the toner ( I would check the feed fins in the chuck first)
Ricoh Aficio... | Answered on Apr 28, 2014
It is a problem with the controller. Or the controller board is not installed correctly or maybe a connector is not connect correctly. It could be the controller is bad and should be replaced.
Ricoh Aficio... | Answered on Jan 18, 2014
Hi, mahesh Van;
The error code sc925, it mean networking problem, check up your network, will be take care this problem.
Ricoh Aficio... | Answered on Nov 01, 2013
Pls tell in which way you are using A4 papers. Landscape or Portrait.? More help contact me on anuruddha07@gmail.com
Ricoh Aficio... | Answered on Oct 19, 2013
Ricoh Aficio 3045, 3035 Kit Logo
18 questions posted
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
ricoh aficio 3045 hard disk problem
  • Office Equipment & Supplies
