20 Most Recent
Nikon D2X Digital Camera Questions & Answers
Error message
Are you getting this while taking a photo? If so, it merely indicates the number of additional photos you can take in the current burst before the buffer fills up and the camera has to slow down. It's NOT an error.
2/8/2024 4:01:39 AM •
Nikon D2X...
Answered
on Feb 08, 2024
Nikon D2X Not powering up anymore - shorted/blown DC board?
do a master reset, holding WB and ISO buttons down together for more than two seconds will reset camera settings.
then replace the clock battery, let it sit with no batteries for a bit.
try to plug it into an external power supply: EH6 if you have one.
i have had most every digital nikon having shot them since the D1 rolled out, and have never had one just crash and die.
I hope this helps, good luck and sorry.
9/27/2017 12:31:06 AM •
Nikon D2X...
Answered
on Sep 27, 2017
Nikon D2x Just stopped taking photos.
To make sure the card is formatted correct, do a format in the camera. I'm not sure if the newest UDMA CF cards are compatible with your camera. But I think you still have an old card, you can format. Please also check all contacts in the camera are still straight. Us a bright light and a magnifying glass.
Also take time to check your battery is still good. I'm sure you have more than one. Also check the battery contacts, if they ate clean and shiny. Only to be cleaned with a dry cloth or cordon swabs.
When you removed the battery, you already did a reset.
Till now I can't think of more to help you.
Success
I love my Nikon
7/24/2014 7:49:26 PM •
Nikon D2X...
Answered
on Jul 24, 2014
Flashing P on screen d2x
Are you sure it is a P you see? not an F?In the whole manual I can't find an error called P.When you see an F, it has to do with the lens. Not in its slot, not fitted correctly. And when FEE is on the screen, the lens is not set to the highest diaphragm. Sometimes the sensor is dirty and will give this FEE random. Or sometimes the error stays, because the sensor is broke.Please tell me it is really a P you see.
11/12/2013 8:35:22 PM •
Nikon D2X...
Answered
on Nov 12, 2013
D2x won't work when a lens is attached
Did you try to reset the camera to factory settings?
Won't work, does that mean everything stays out? Or you can't make a picture and still view pictures you made? Is there an error in the display, like fEE. That would be caused by the sensor, looking if your diaphragmatic setting on the lens is locked on the smallest aperture.
Could be dust, or worse the sensor is damaged. Then the camera must be repaired.
10/25/2013 10:24:56 AM •
Nikon D2X...
Answered
on Oct 25, 2013
D2X won't power down!!
Sounds like there is a problem with the image compression board. Send it to Nikon - replacing the board requires programming with Nikon's proprietary program.
4/11/2013 3:46:28 PM •
Nikon D2X...
Answered
on Apr 11, 2013
