20 Most Recent
Elite Logitech Media Keyboard(KB9675590403 Questions & Answers
I have a wireless keyboard HP 521purf that I used
Sometimes with different hardware from different companies are not universally supported, if it is a Bluetooth keyboard then most likely its different than the actual factory standard Bluetooth keyboard for the IOS(Apple) technology and will not work unless you have an IOS or (Apple) certified type of technology that can be used for your personal use in the technology it supports If you need further help, I’m available over the phone at
https://www.6ya.com/expert/brant_4c68df22dda524c2
Key board hard to print
possible reasons:
is your keyboard dirty? can u see crumbs or dust or pet hair ect in between the keys? if so you can try cleaning them by using a toothpick or something to break the stuff lose between the keys and then flip the keyboard over for the stuff to fall out. you can also pop each key out, using a knife, but do one key at a time, and put them back in as you go, so you don't put a key in the wrong place or forget where they go.
other then that, if your keyboard came with a install cd, then you may need to either download and reinstall any drivers or software that came with it. Other then that their isnt much more you can do to test or fix it.
When setting up the
all functions are =controlled by setpoint
turn off your anti virus and uninstall then reinstall this setpoint.
ftp://ftp.logitech.com/pub/techsupport/mouse/setpoint440.exe
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Kenmore elite touchpad not working
If the touchpad on your Kenmore Elite refrigerator is not working, there could be several reasons why. Some possible causes include:
- Dirty touchpad: Make sure that the touchpad is clean and free of any debris or spills.
- Power supply: Make sure that the refrigerator is plugged in and that the outlet is providing power.
- Control board: The touchpad may not be working if the control board is damaged or malfunctioning.
- Control lock function: Make sure the control lock function is not engaged.
- Software issue: It could be a software issue, update the software of the fridge to the latest version.
It's worth trying these solutions one by one and check if the touchpad starts to work. If the problem persists, it would be best to contact the manufacturer's technical support for further assistance. They may have more specific troubleshooting steps to help you fix the issue.
