20 Most Recent
Maxidiag Pro MD801 Questions & Answers
What is car diagnostic tools ?
car diagnostic tools is tools used on the car ,it can check the data and point the right direction in the car , you can also go the website www.drsets.com to see more about the diagnostic tool
Does a 2008 Sienna need replacement airbags
Since we have no way of knowing whether they have updated owner information, and even if they do, whether they would contact you, type in "Airbag recalls" and "Sienna recalls" and "factory recalls" into your search engine, and go after this information, if you cannot go to your local Toyota dealer.
Since not all dealers are created equal, you might want to do that anyway.
God bless your efforts.
(I am having the same questions with my 2 Toyotas)
Rover 75 faults problems
It's usually poor contact in the pre-tensioner wires under the seats, specifically the passenger seat. Rovers are particularly susceptible to it if the sunroof leaks (that will be 99% of rovers then).
Disconnect the battery for 10 mins then clean up the multiplugs with contact cleaner and a cotton bud and check the wires for chafing. Although the book says the light needs resetting with a diagnostic reader, Ime the warning light usually extinguishes itself once the problem is fixed if it is simply down to a bad contact.
Scanner check
well I am going to suggest rewording your question please because what's typed up there now my about as much sense as snow in Florida !!!
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
What is hashtag
hash·tag
noun
(on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
1944c Furuno radar array won't spin 7 years old. Just beeping
It seems like you're dealing with a technical issue related to a Furuno radar array. If the radar array is not spinning and is emitting a beeping sound, there could be several possible reasons for this problem. Here are a few steps you can take to troubleshoot the issue:
- Check Power Supply: Ensure that the radar array is receiving proper power. Check the power cables, connections, and any fuses that might be relevant. Make sure the power source is functional and providing the correct voltage.
- Inspect Mechanical Components: If the radar array won't spin, there could be a mechanical issue with the rotating mechanism. Check for any obstructions or debris that might be preventing the rotation. Lubricate any moving parts if necessary.
- Connection and Wiring: Examine the connections between the radar array and its control/display unit. Loose or damaged cables could cause communication problems and result in the array not spinning. Ensure all connections are secure and undamaged.
- Software and Configuration: Sometimes, software settings or configuration options can affect the operation of the radar array. Check the user manual or documentation to ensure that the radar is properly configured. Try resetting the settings to default and see if that resolves the issue.
- Error Codes or Messages: If the radar is emitting beeping sounds, it might be indicating an error condition. Refer to the user manual or any accompanying documentation for a list of error codes or messages and their meanings. This could help pinpoint the problem.
- Contact Support: If you've tried the above steps and the issue persists, it might be best to contact Furuno's customer support or a qualified technician for further assistance. They can provide more specific guidance based on the model of your radar array and the symptoms you're experiencing.
Remember, working with electronic equipment requires caution to avoid electrical hazards. If you're not comfortable troubleshooting the issue yourself, it's always a good idea to seek professional help.
