ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
179 questions posted
75 Questions
77 Questions
51 Questions
39 Questions
39 Questions
