20 Most Recent Akai PTH5498 54" Rear Projection HDTV-Ready Television Questions & Answers
Akai pt5499hd
Either the convergence chip has gone bad or the Focus block is bad. In any case,you will need to consult with a professional technician to solve this problem
11/12/2017 1:06:53 AM • Akai PTH5498 54"... • Answered on Nov 12, 2017
Akai hdtv 1080i no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
9/3/2017 2:45:52 PM • Akai PTH5498 54"... • Answered on Sep 03, 2017
My Akai 5498 picture is yellow and i can't
One or more of of the crts on set is burnt out and needs replacement.
10/11/2015 12:43:11 AM • Akai PTH5498 54"... • Answered on Oct 11, 2015
My tv turns on , red light flashes, then clicks off
check kill switch on the lamp cover door it should be firmly pressed by the lamp door
7/20/2013 11:12:25 PM • Akai PTH5498 54"... • Answered on Jul 20, 2013
Picture looks yellow
The image settings has changed it may be in sepia.. Just change it in camera setting or image setting into auto or normal ,,
7/19/2012 12:35:54 AM • Akai PTH5498 54"... • Answered on Jul 19, 2012
AKAI model PTH5498 turned it on in morning and it worked fine, then went to kitchen then heard a pop then a buzzing noise tv had no picture
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
5/17/2012 2:51:38 PM • Akai PTH5498 54"... • Answered on May 17, 2012
We stored the tv for a year then moved now the screen is out of focus
3d looking? or not clear?
4/28/2012 2:52:33 PM • Akai PTH5498 54"... • Answered on Apr 28, 2012
My akaipth5498 projection tv shows a dark picture, even after adjusting colors. it looks like a bootleg movie.
If you unplug the set and look with the back cover removed you will find 3 large black round lens inside---light source (red,green,blue) for your picture--clean them with a lens cloth or a paper towel with glass cleaner sprayed on the towel.Should be done about 1 time a year.
4/27/2012 12:01:37 AM • Akai PTH5498 54"... • Answered on Apr 27, 2012
Need to find and print an owners manual for my
the user manual is available at the following link its delivered by download within minuteshttp://servicemanuals.vstore.ca/product_info.php/pName/akai-pth5498-user-manual
10/29/2011 1:34:52 PM • Akai PTH5498 54"... • Answered on Oct 29, 2011
Akai red and green ghosting
This is a convergence problem and fixable. Click here.
Jdvillanueva
10/1/2011 1:26:31 PM • Akai PTH5498 54"... • Answered on Oct 01, 2011
Picture seems very faded on
If model number is correct the akai is a samsung; from the rear with the cover removed are three rather large black lens (one for each picture tube) that point upwards.If the set has not been serviced for a long time clean the lens with a lens cloth or a paper towel with glass cleaner sprayed on it.These are the light source for your picture and if dusty the picture will be darker and dull looking.SD TECH
9/21/2011 8:28:18 PM • Akai PTH5498 54"... • Answered on Sep 21, 2011
I plug in my tv
The sound of it sounds like a power board transformer that went out on you, Looking up that part lands you about $95 bucks labor about $200 depending.
So its all up to you on where you want to take it.
I did also mention trying to sale it for parts to help you sustain for a newer set.
Thanks or using Fixya.com
Rulds2008 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
9/3/2011 12:27:23 AM • Akai PTH5498 54"... • Answered on Sep 03, 2011
My remote will not work
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help with your problem.
Thanks for using FixYa and for the great rating.
hardrocko
8/16/2011 1:37:25 AM • Akai PTH5498 54"... • Answered on Aug 16, 2011
I have a pth5498 when
There could be many items that can cause that symptom. However I always assume convergence on any rear projection which can easily be checked by unplugging the convergence amp board and then plugging in the set and press power , if the set powers up turn it back off, and you will know the convergence ICs and associated resistors on that board have failed. Although its easier to replace the board unless you have good soldering skills. I am pasting a pic of the board which is suspended above the main chassis just mark the wires then unplug the set from the wall first, but then unplug the wires from that board and then try powering up the set.if you need further assistance , respond to this same post slinteriors_21.jpg
8/12/2011 2:56:10 PM • Akai PTH5498 54"... • Answered on Aug 12, 2011
My tv blinks 4 times
Yes - that is one of the possible symptoms. TV will shut down with no audio or video. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
8/11/2011 9:49:01 PM • Akai PTH5498 54"... • Answered on Aug 11, 2011
My picture was prodominately green/red. I took the
1.) It means the Glycol in the blue tube is bad--usually contaminated by bacteria--each of the 3 picture tubes has a sealed area between the face of the tube and the lens above.
2.) If you see a picture in Green and RED but blue looks like a floodlight--the blue tube would have to be removed, drained, and the area with the Glycol washed out---new glycol added and the tube resealed and installed back into the set.
3.) This is a fairly major repair--the Glycol is very toxic---like antifreeze but much more concentrated---unless you have done it before I would not suggest it as a do it yourself job.
4.) The bacteria never affects the RED(it does not seem to like that color) and only sometimes the Green.
5.) It may not be worth repairing as most shops charge 200-300 or more for this kind of repair---not to mention that after it is done quite a lot of adjustment to the convergence will be needed from removing and reinstalling the tube.
6.) I know I am not giving you good news but you actually found your problem yourself! If you need any advice or help reply to this post and I will try to assist you.
I do this here for free so if this information helped you please take a minute to give me a vote here.
REGARDS, SD TECH
5/17/2011 3:24:17 PM • Akai PTH5498 54"... • Answered on May 17, 2011
Akai PTH5498 54" Rear Projection HDTV-Ready Television Logo
193 questions posted
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Akai Televison & Video
Most Popular Question
tv wont turn just
  • Televison & Video
